Your source for Mazda shift boots from Redline Goods!
+ Reply to Thread
Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 35
Thread: How To: Moonroof Always On
  1. #1
    Electro-modder ZapWizard's Avatar
    Join Date
    Jan 2004
    Location
    Austin, TX
    Posts
    250
    If someone could please move this into the How To forum, thanks.
    Always On Moonroof
    2003 Mazda Protégé - By ZapWizard
    If you have modified your power windows so that you can run them even when the car is off, you will find that the moonroof is on a seperate circuit.
    With a few more steps, the moonroof can also be wired for always on operation.
    This is part one of my modification, the second part will be making a rain-detector circuit, that will allow the moonroof to automatically close if it starts raining. This will allow me to park my car with the moonroof venting air out, yet not worry about water getting into the car. An alarm system later will also be able to close the moonroof if someone is too close to the car.
    The tools needed are:
    • Philips screwdriver
    • Flathead screwdriver
    • Tiny flathead screwdriver
    • Normal pliers
    • Needle nose pliers
    • Wire cutters
    • 1 QTY: 16-22 AWG Wire taps
    • 2 QTY: 14-12 AWG Wire taps
    • 1 QTY: 15-Amp mini-fuse
    • 1 QTY: Wired mini-fuse holder
    This modification is not as easy as simply wiring the moonroof to battery power, like the power windows.
    This is because the moonroof is connected to the 15-amp A/C fuse inside the fuse box, and the wire running to the moonroof is also connected the rear window defrost, so we have to separate and re-wire both these connections.
    So far I have not found that any other circuits are on this same wire, so I doubt there is anything else on the wire that could drain the battery.
    As will all modification: Do at your own risk.
    The first few steps are the same as modifying the power windows.
    Remove the bottom-trim on the door by pulling up on one side.
    Pull up about six inches of door trim
    Pop off the push-bolt at the back of the fuse-box cover.
    Pull the fuse cover off by pulling the backend towards the center of the car.
    Locate the Defrost control relay, this is attached to the top of the fuse box.
    If the car is on, you should hear this relay click when you press the rear-defrost button.
    Remove the defrost relay and its holder.
    Note: This modification is possible without removing any wires (only cutting them), but I found it easier to work with the wires away from the fuse box.(And to make sure I don't cut the wrong pink wire)
    You need to remove the pink wire on the defrost relay.
    You do this by pushing up on a pin inside the holder.
    Once disconnected you can test by pushing your rear-defrost button, this relay should no longer click on. (Even though the defrost button lights up)
    Note: This pink wire is shared with the moonroof, and is connected to the 15-amp A/C fuse in the fusebox.
    Once that wire is loose, you need to remove the top-most connector on the fuse box.
    You then need to pull the pink wire located at the top of the flat side of the connector.
    If you look at the connector as if it was plugged into the fuse box, it would be the top-most wire towards the center of the car.
    If you are not sure, remove a wire, plug the connector back into the fuse box, turn on the car, and test if you can open your moonroof.
    (It should not open)
    Note: This pink wire is the power-output for the moonroof and rear-defrost relay.
    You should now have two pink wires hanging from the tape-wrapped bundle of cables.
    (One with a large metal connector, and one with a small metal connector)
    These two wires are connected together somewhere, and still have an electrical connection between them.
    (You can confirm this with a continuity meter)
    The only circuit these should be connected to now is the moonroof.
    Cut the pink wire with the larger connector about three inches from the electrical tape bundle.
    Cut the pink wire with the smaller connector in the same way.
    You should now have two pieces of pink wire.
    We will use these to restore the rear defrost relays connection to the fuse box.
    Using a 22-16 Gauge wire tap, clamp the two wires together, and close the tap.
    I also recommend that you test their connection with a continuity meter.
    You can now push the connectors into their original spots on the fusebox, and defrost relay.
    This will complete the relay part of the modification, and your rear defroster should function like normal.
    Note: These steps could have been done by simply cutting the wires without removing them, and then splicing them back together.
    You should now be left with two cut and loose wire hanging from the tape-wrapped bundle.
    We need to splice these (with a fuse) onto a battery wire to allow the moonroof to work when the car is off.
    There is a battery wire conveniently located right on the rear defrost relay.
    It is white with a red stripe.
    So first we need to splice our fuse holder onto the battery wire.
    (Don't install the fuse just yet)
    Using a 14-12 Gauge wire tap, clamp the fuse holder onto the battery wire.
    Next, we need to connect the two loose pink wires onto the other end of the fuse holder.
    Using a 14-16 gauge wire tap, insert both pink wire into one side of the tap, and the fuse holder into the other.
    Then crimp the wires together.
    Even though the pink wires are thin, I have found that splicing both of them together provides enough connection that they don't pull-out of the wire tap.
    The last step is installing a 15-amp fuse into the fuse holder.
    You can test the moonroof now if you want, if it works you can start putting the fuse box and covers back together.
    If you want to reverse this modification, you can take the tap off the battery wire, and splice it back onto the pink wire running to the defrost relay.
    Done!
    You should now be able to operate your moonroof anytime you want.
    www.ZapWizard.com
    -Advanced Computer Modification-
  2. #2
    Banned Brian MP5T's Avatar
    Join Date
    Jul 2003
    Location
    Ottawa Ontario
    Posts
    11,565
    Donated: $5
    That is about as "In Depth" As I have seen it. Good job.
  3. #3
    stop honking I'm surfing Poseur's Avatar
    Join Date
    Oct 2003
    Location
    Richmond Beach, WA
    Posts
    3,087
    Donated: $20
    Dude, you're a big help, thanks again. I'm in the process of hooking up my windows and sunroof to my alarm, and finding the power for the sunroof was really starting to bug me. One thing,though. if you're taking the time to get into them, why use the ghetto splice-blocks? especially if you've got 'em out of the car, twist and solder and shrinkwrap, or atleast electrical tape 'em... makes everything WAY cleaner.
    Carputer work in Progress...
    Athxpmobile2200+, MSI kt6v-lsr MB, opus 150w dc-dc, 512ram, dvd/cdrw, bluetooth, wifi, XM...Installed and near-daily functional since 4/12/05
    Audio:
    Eclipse CD8454 HU, 14g wire pulled to doors toreplace my quad vifa 4's. 3-way setup with kicker SS56.2component set in kicks and Kicker SSMB8 (8" midbass) in door Amps: Avionixx NXD2400M. AXA600.4, MonsterCable/Phoenix gold wires. Sound deadening/carpetpadding everywhere. 12" Eclipse 7324 Alum squeezed into a 1.2cuf f/g box Misc electrcal:Code PC70 2-way alarm (remotestart, windows, snrf) w/autoloc window modules wired for one-touch up all around, AC/fresh air defrost switch disabled. Blue&Red LED's for ac/defrost/fresh/recirc lighting. retained window/sunroof power, one-touch sunroof, 1sty's Groundwire kit, Optima Redtop Exterior:Yakima rack (I'm a bike/board geek it's necessity), '03 MSP wheels, Espelir springs, Protege5.com stickers, 20/30% tint, DaveB "Protege5" shorty Antenna, Simple bicycle co. stickers Protege Garage custom dex-made hood prop kit Interior:B&M short shifter w/shaundarbie shortshifter boot, Wet Okole neoprene seatcovers, DaveB's brushed finish instrument rings.
  4. #4
    Join Date
    Jan 2004
    Location
    Austin, TX
    Posts
    250
    Well I am using the wire taps mostly for speed, as I am a technican 8 hours a day, a PC modifier 6-hours a day, and only have a few hours left over for side projects.
    Plus they are not visible in the end.
    BTW, This mod took about an hour to complete.
  5. #5
    P5 to P5T to WRX to Z06 Matthew's Avatar
    Join Date
    Jan 2003
    Location
    Fort Huachuca, AZ
    Posts
    17,196
    Donated: Stopped $5/mo
    Afghanistan Moderator
    very nice write up. now do one for a clutch install lol
  6. #6
    Join Date
    Oct 2003
    Location
    Richmond Beach, WA
    Posts
    3,087
    Donated: $20
    ah that's cool, Just sorta my thing I guess. I hate having to look at messes of tangled wire even if it's behind a panel. Not to discount you at all, again, thankyou.
  7. #7
    Boostd & it feels so good Moeed's Avatar
    Join Date
    Sep 2003
    Location
    DFW, TX
    Posts
    2,153
    Nice job, can you tell me when you say test to see if the moonroof works after you take out the smaller pink wire, do you want it to work or should it not work any more?
    Again, nice write up. been waiting for some one to do this for a while.
    http://dfwmazdas.com
    MSP Swap with MPNick upgrade , ION FMIC, ION CAI, MPI TUNER and extra injectors , AWR Competition Radiator with custom fan shroud, J&S safeguard , zeitronix w/b with all the extras, blitz DSBC at stock and 9 pounds, Front and rear mount 90 durameter, Intake manifold clean up, and 3" mandrel bent exhaust with ghl d/p. Custom carputer (thanks elemental)
  8. #8
    Join Date
    Jan 2004
    Location
    Austin, TX
    Posts
    250
    Quote Originally Posted by Moeed
    Correct, when you first remove the pink wire from the fuse box, you can turn the car on, and test to see if the moonroof opens.
    It should not open.
    You can also try pressing the rear defrost button, the light will turn on, but you shouldn't hear the relay above the fuse block click on.
    I have been quite a few days since I did this, and I have seen zero problems, my battery doesn't drain overnight, and there doesn't seem to be any other circuits on that wire.
    I got more guides coming as I mod other electronic stuff.
  9. #9
    Join Date
    Sep 2003
    Location
    DFW, TX
    Posts
    2,153
    Zap, i know this is a little off topic but be sure to come out to the texas meet.
  10. #10
    Join Date
    Jan 2004
    Location
    Austin, TX
    Posts
    250
    I will be there for the saturday events.
  11. #11
    Join Date
    Oct 2003
    Location
    Richmond Beach, WA
    Posts
    3,087
    Donated: $20
    Has anyone found anything else on this circut yet? I just integrated my windows into my alarm, and intend to do the sunroof soon, but I just want to make sure nothing else's gonna be a problem.
  12. #12
    Join Date
    Jan 2004
    Location
    Austin, TX
    Posts
    250
    Quote Originally Posted by Poseur
    I have been running it since I wrote the guide with zero problems, and I haven't noticed anything else working out of the ordinary.
  13. #13
    Join Date
    Oct 2003
    Location
    Richmond Beach, WA
    Posts
    3,087
    Donated: $20
    zap>
    Thanks alot, you're the man. I'd have never had the patience to figure this one out myself. Just did it in 15mins thanks to your guidance. I'll see if I cna get it hooked to my alarm tomorrow. Best way for sunroof integration seems to be right at the switches, as things are fairly self-contained up there. If you haven't gotten up into it yet, Just pull the maplight/switch assy down, there's a metal spring clip on each side holding it up. It all becomes very clear fast.
  14. #14
    INCUBUS!!! mrpopnfresh's Avatar
    Join Date
    May 2003
    Location
    So Cal
    Posts
    428
    Potential Scammer!
    Nice write up. I've been wanting to do this for some time now.
    Banner by Sukegirl_mp3
  15. #15
    Registered User
    Join Date
    Jan 2003
    Posts
    5,757
    Donated: 20$
    hah! We were just talking about this the other day. Thanks a lot. I'll be trying this tomorrow.
+ Reply to Thread
Similar Threads
  1. moonroof rattle
    By eting_pro5 in forum Protegé 5 (Protege5.com)
    Last Post: 10-30-2003, 09:00 PM
  2. Automatic sliding moonroof
    By Coqui258 in forum Protegé based Appearance
    Last Post: 08-25-2003, 08:00 PM
  3. moonroof defect?
    By ottawaP5 in forum Protegé 5 (Protege5.com)
    Last Post: 05-19-2003, 07:32 PM
  4. small moonroof
    Last Post: 03-14-2003, 03:02 PM
  5. should i get a moonroof?
    Last Post: 02-08-2003, 07:30 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
