Mazda Competition & Factory Parts @ Racer net pricing! Go Tri-Point!
+ Reply to Thread
Page 1 of 5 1 2 3 ... LastLast
Results 1 to 15 of 65
Thread: How To: Install Amp Wiring Kit
  1. #1
    'Content Monkey' derrick1623's Avatar
    Join Date
    Oct 2001
    Location
    Windsor, Pa
    Posts
    3,019
    Donated: $40
    ADMIN
    HOW TO: Install an amp wiring kit
    the kit contains a power wire, a ground wire, a remote turn-on wire, and RCA jacks
    • passenger side of engine bay.
    • to the left of where these wires enter(next to the wires but still inside the grommet), you can feel where to go.
    • go inside the car, and pop out this cover panel.
    • then, pop out the one one the right side...
    • after that, pull the carpet down like so...
    • then, poke a small screw driver through like this...
    • follow that up with something the same thickness as your power wire (i used a bigass lag bolt, but whatever.). tape the wire to whatever you used using a tape that wont hang up...and CAREFULLY slide it through the grommet, you may need an extra set of hands here.
    • then, the in-line fuse...
    • ok, now just run the other end of the wire all the way to the trunk, to get it under the middle plastic piece, pull it up about a half inch.
    • fish the wire under the rear seat bracket, after going under the side of the seat.
      that's it for the power wire.
    • the ground wire is easy. move the stock sub out of the way and pull back the carpet from inside the car...ground it here.
    • for the RCA and remote wires, i ran them together so i didn't have to do it twice.just run them like the other side... and thats it.
    r.i.p. Mazda MP3 #556-"blue streak"
    2007 Mazda3, I-Touring - True Red, Sirius Starmate 4, moonroof deflector ... with SITE STICKERS!
    5" tv and volt-gauge custom fiberglass pod, ps2, 10" Kenwood sub(MP3 model), polk audio 5250 5 1/4" components...tv replacing ashtray,current project.
  2. #2
    the anti-rice pro5utah's Avatar
    Join Date
    Feb 2003
    Location
    Utah
    Posts
    152
    But my question is how you get the stereo stock) out to be able to run the remote and RCA's. Anyone plan on doing that here? I am probably just going to run a line converter off of the rear speaker lines and then RCA's off of that for now.
  3. #3
    Registered User JAC's Avatar
    Join Date
    Oct 2002
    Location
    Caracas,Venezuela
    Posts
    484
    This guy has an Mp3 with the "stock" kenwood HU. Ask SirNuke, he did what you're planning to do on his P5 with the stock HU.
  4. #4
    323 Sport 2.0 323Sport's Avatar
    Join Date
    Oct 2002
    Location
    ESTONIA
    Posts
    127
    You should not run the power, RCA and system remote together from one side, since it causes some drop in sound quality. Run the power cable from one side of the car and the RCA from the other.....
    edit, sorry you did run them from different sides...
  5. #5
    Registered User shackles10's Avatar
    Join Date
    Mar 2003
    Location
    Kokomo, IN
    Posts
    75
    how bout the completely easy to remove grommet on the driver's side?? i noticed you said he has an mp3 but i know on the pr5 there's a grommet you can pop out and 4awg fits right through easily. if you're looking for it, it's almost straight behind the battery on the firewall a little less than halfway down. pops right out, wire slides right in.
  6. #6
    powered by FLIP traitorhound's Avatar
    Join Date
    Jan 2003
    Location
    Orlando, FL
    Posts
    1,799
    can i get a pic of where this grommet is form teh inside and the outside of the car please? im a retard and can't seem to find it and i really don't want to poke a hole in the passenger side grommet (looks hard to replace if i mess it up somehow. . . .heh)
    thanks
    1st BuddyClub2 P5 2003 Midnight Blue Mica P5 5-speed, moonroof HKS Hi-Power axelback, Bronze rota subzeros, kartboy bushings/short shifter/knob, Carputer, tein stech springs, mp3 struts, mp3 sway, gt spec lower tie bar, awr front motor mount, obx header, ebay cai, hornet 2-way alarm, airdynamic racing seats
  7. #7
    Join Date
    Mar 2003
    Location
    Kokomo, IN
    Posts
    75
    i'll be out of town all weekend so no pc access. if someone else wants to put a pic of it on here then by all means go ahead, otherwise just give me your email addy in the next half hour and i have a camera in my cell phone. i'll just snap a couple pics and send them to you.
    p.s. you'd not believe how awesome having the camera in the phone is. all i have to say is some of the only pictures probably to ever leave a strip club lol
  8. #8
    Registered User Yaegs4life's Avatar
    Join Date
    Oct 2003
    Location
    PHILY
    Posts
    49
    Does any1 know how to remove the stock stereo?????
  9. #9
    Rebuild almost done :) joka1's Avatar
    Join Date
    Apr 2003
    Location
    Anacortes,WA
    Posts
    5,120
    Donated: $20
    ya..... get the ford stereo removal u shape things(or cut and bend a coat hangar right) you need 4 total..... pop off the sides of the stock radio and insert the removal tools into the 8 holes and pull!!!!!
    Member Of:Project1
    View my feature in MazdaSport: Thread
    APRIL ROTM -Thanks once again!!
    Protege is ALIVE..Finally Running-Rebuild Thread #3
  10. #10
    avatar de controversial ahb11m's Avatar
    Join Date
    Aug 2003
    Location
    North Brisbane, AUSTRALIA
    Posts
    944
    extra note
    - you will need to squeeze the things to the side (which side i forget - sorry) eithere in or out, you'll work it out i'm sure... make the coat hanger stay in a u shape, making sure the ends arn't sharp, and the U shape is even - ie both tip ends line up you'll feel the coat hanger on a bit of resistance when going in - push harder, till you feel it meet a butt stop then do the squeeze and yank the thing out towards you!! too easy
    ps if your replacing th HU i highly recommend using a mazda adapter to open wires, make life a lot easier if using stock wires, or just rewire the sucker
    serrick i put mine under the drivers seat, thing is secure, doesn't get in the way of anything, and is a bitch to remove (read - steal) i just screwed the thing straight down into the floor with a gap of 10mm between the carpet and the amp bottom for ventilation or something - also only a few wires to disconnect in the boot, with no risk of shorting out, if ya remove your box!!
  11. #11
    Join Date
    Apr 2003
    Location
    Anacortes,WA
    Posts
    5,120
    Donated: $20
    thanks for the extra note!!!!! p.s. if you cant get it out.... take it to the dealer...they took mine out for free when one of the locks that hold it in broke!!!!
  12. #12
    Join Date
    Jan 2003
    Location
    Orlando, FL
    Posts
    1,799
    yea tha'ts how i got mine out. . .cause one of the tabs were bent and they had to take out by taking off my center console pice......i wish i knew about that back thn. . .cause they scratched some parts taking it out. . ..and i know how to do it myself. . .as my center console radio surround has been an LCD surround for a while now
  13. #13
    Registered User
    Join Date
    Nov 2003
    Posts
    13
    Originally posted by ahb11m
    extra note
    If you're a sound quality freak, mounting it directly into the floor isn't the best route. If you have the room, mount it on a piece of wood (insulator). This prevents any type of ground noise associated with screwing it straight into the metal. Just my $.02
  14. #14
    Join Date
    Aug 2003
    Location
    Posts
    944
    if your a full SQ fan would of thought you'd want to keep the wires short, and close to the box??????????.... (i'm guessing)
    but yeah mine is good where it is, i just used some small wood blocks (off cuts) to raise it, but no sheet of lumber... maybe i'll do that, but i couldn't be bothered to ATM...
  15. #15
    Experianced noob loccusst's Avatar
    Join Date
    Oct 2003
    Location
    Iowa...middle of nowhere
    Posts
    645
    An extra bit is to make sure when crossing over other wires to do it as little as posible. Don't run your stereo wires close to the wires in the car if you don't have to. Lastly if you do cross over other wires to go across them as straight as posible like a plus sign instead of a "x".
    Anyone can drive fast in a straight line ...... Its driving fast around corners that takes skill.
+ Reply to Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
