JSCspeed.com - Your Source for IN STOCK Mazda Performance Parts!
+ Reply to Thread
Page 1 of 4 1 2 3 ... LastLast
Results 1 to 15 of 50
Thread: How To: Stop the P5 spoiler from rattling!
  1. #1
    zoom zoom, eh? ChopstickHero's Avatar
    Join Date
    Apr 2002
    Location
    Toronto, Canada
    Posts
    4,561
    Donated: $10
    HOW-TO: Stop the P5 spoiler from rattling!
    Materials needed:
    Flat head screwdriver
    Phillips screwdriver
    Deep socket (size 10 metric) and ratchet
    Sharp Exacto Knife
    Masking tape
    3/16" thick weatherstripping
    2 beers
    1. Open hatch and locate the 4 plastic covers on the underside of the hatch
    2. Wrap up your flat head screwdrive with masking tape and pop out the plastic covers. if it's cold, the plastic may crack or deform a little. but careful not to scratch up your paint (hence, using masking tape). Repeat for all 4 covers.
    3. Use your phillips screwdriver to take out one screw. you should only need to take out one screw and leave the other screw in b/c it will swivel.
    4. To detach the parking brake wire, pull out the wire and detach the little white clip.
    5. Take your deep socket metric 10 size and ratchet to loosen and remove the bolts that attach the spoiler to the hatch. becareful not to drop them inside the hatch or else you'll have a b!tch of a time taking them out. if you do drop it, use a magnetic picker upper or a piece of wire with some tape attached to it. repeat for all 4 bolts.
    6. There are 2 clips that attach the spoiler to the hatch. Remove the spoiler by pulling spoiler upward, away from the hatch. Also, there is a rubber grommet that prevents water from entering the hatch, wiggle it and pop that out too.
    7. This is the part that rattles. The black plastic surrounding the brake light is the piece vibrating against the spoiler. Remove the 7 screws that hold this black plastic to the underside of the spoiler. There are actually more holes than screws (7 screws and 9 holes), so remember where the screws came from.
    8. The weatherstripping that i used was 3/16" thickness. you could use a thinner one, but i wanted to be sure there would be enough dampening.
    9. Cut the appropriate lengths of weatherstripping on each side of the brake light. tape them securely, making sure that the tape is evenly spaced and not sticking out anywhere.
    10. You may find that when test fitting the black plastic and spoiler, the weatherstripping foam maybe a little thick. Begin to insert the screws and you will see that the weatherstripping will compress nicely between the black plastic and spoiler. do some test fitting so that the weather stripping fits correctly. make sure you tighten the screws on the brake light as well.
    11. At this point, i used a sharp exacto knife and trimmed the weather stripping. it cuts very easily and i wanted a cleaner look.
    Johnny5 being very helpful with the project and playing Vice City....
    12. Before installing the spoiler back, make sure to clean the spoiler and hatch areas. Now install in the reverse order of removal.
    13. Done! Now open your beers and blast some tunes and enjoy some of the bass instead of the damn spoiler rattle! I had NO spoiler rattle whatsoever .... but did hear some rattle in the bumper ... :crazy: ... but that's another How-To.
    Johnny5 gives his seal of approval!
  2. #2
    ...and it was all yellow cbcbd's Avatar
    Join Date
    Jan 2003
    Location
    Seattle,WA
    Posts
    3,212
    Donated: 5$
    Nice write up. I'll have to check to see if I do have this rattle. I have other rattles that are more apparent that I yet have to tackle.
    2002 Yellow Pro5 #100,994
  3. #3
    Vivid Yellow P5 Owner YlowP5's Avatar
    Join Date
    Mar 2003
    Location
    Santa Clara, CA
    Posts
    42
    Great, easy to follow write-up. I haven't noticed a rattle in the spoiler... I'll have to crank the bass, get out of my car and listen for the rattle.
  4. #4
    Join Date
    Apr 2002
    Location
    Toronto, Canada
    Posts
    4,561
    Donated: $10
    Thanks for the compliments. It was really easy to do.
    I only have one 12" Alpine Type-S with about 200W RMS... and it rattles like a mofo!
    after i got rid of the spoiler rattle, i found 2 other rattles in the bumper; one on the left side and one on the right side. apparently they are some kind of wind noise reducing hard rubber/plastic fins that are on the sides of the bumper. if you open your jack access, put your hand through that hole and you can feel it vibrating if you have your subs on. it'll be harder to get to this, but i'm gonna try soon.
  5. #5
    King of the City! NRRfrogmanP5's Avatar
    Join Date
    Feb 2003
    Location
    chicago, Oak Lawn
    Posts
    8,404
    Donated: $10
    FS, IL, OT & Protege5.com Moderator
    thats prolly what rattles on my car...i never thought of it bein the spoiler
    zoomzoomzoomzoomzoomzoom im still following u james
    MAZDATEAM OFFICIAL STALKER OF ZUKU26
    Mazdateam/IL Section Pro Football Pickem 2009 co champ
  6. #6
    Kraken=Gamertag DeanSweet's Avatar
    Join Date
    Apr 2003
    Location
    Springboro, Ohio
    Posts
    1,421
    Donated: $10
    Great write up on how to remove it.
    I just applied a couple strips of dynamat to the inside back of mine and voila, no more rattle. Same idea, just removes the chance of that pos plastic from vibrating against the glass.
    It's a dog eat dog world... and unfortunately for me, I am wearing boxers made with milk-bone dog biscuits?!
    -Dean
  7. #7
    Registered User ottawaP5's Avatar
    Join Date
    Jan 2003
    Location
    Hull, Quebec
    Posts
    1,288
    Shouldn't you drink the beers while working?
    2010 VW GTI
    2007 Mazdaspeed 3 - Sold
    2006 Mazdaspeed 6 - Traded
    2003 Mazda Protege 5 - Traded
  8. #8
    Registered User Douggie's Avatar
    Join Date
    Nov 2001
    Location
    IN, USA
    Posts
    720
    Great job! This is the stuff that makes this forum so great!
    2002 P5 Midnite Blue
    __________________
  9. #9
    Join Date
    Apr 2002
    Location
    Toronto, Canada
    Posts
    4,561
    Donated: $10
    that could work too. but being 11am when i was working on this, i had to wait at least an hour... just to tell myself that i'm not an alcoholic... but the beers were flowing just after noon ...
  10. #10
    Officially Retired CitizenPro's Avatar
    Join Date
    Sep 2002
    Location
    Houston, TX
    Posts
    5,125
    Donated: $11.67
    I had the same rattling....in the spoiler and inside of the bumpers! I got rid of my sub awhile back, but ill be getting some more....ill be sure to use this "How-To" to stop it.
  11. #11
    Top Mount'in EJ20 RAAZ227's Avatar
    Join Date
    Feb 2003
    Location
    Washington, D.C.
    Posts
    1,123
    Donated: 15$
    good write! Felt like I was reading a color instruction manual!
    *2007 UGM WRX STi*
    *Former 2002 Protege5 owner*
    Spool Stage 2
    TiAl wastegate & bov
    FS-ZE-intake cam
    Mazdaspeed-exhaust cam
    Mazdaspeed axle back
    ACT 6-puck clutch
    Groundcontrol coilovers
    B&M short shifter
    -Heaven-
  12. #12
    Doer Of The Undone nightbluknight's Avatar
    Join Date
    Sep 2003
    Location
    Ft. Huachuca, AZ
    Posts
    11
    Man I must say that due to the beat out that I have in my MP5 this info was highly need. Thanx cat for the post. 1
    Chaser of the MOON...at home among the STARS
  13. #13
    Registered User
    Join Date
    Sep 2003
    Location
    haleyville
    Posts
    21
    good post i will be doin some work before long. thats my main rattle and all i have is 2 kicker comp 12's but gettin rid of them for 2 solo barics or 2 w6 12s. and im sure ill have a fe more after gettin them.
  14. #14
    *M-SPEC MEMBER*
    Join Date
    Oct 2003
    Location
    Honolulu
    Posts
    487
    dang, i feel stoopid!! i just put up a thread on asking how to stop vibration in the wing!! sorry guys ill go delete it! thanks!!
    peace....
  15. #15
    *M-SPEC MEMBER*
    Join Date
    Oct 2003
    Location
    Honolulu
    Posts
    487
    gonna do it this weekend! the rattling is horrible!
    chopstick hero...thanks alot! was thinking bout putiing the dynamat but well see! i also noticed a rattle on the right side of the rear bumber! real suttle tho, not as bad as the spoiler! but again thanks! ill let you know how it turned out! the liscense plate is a prob too! not a biggie tho! just the real deep bass songs! thinking bout using double sided tape to just hold but i dunno? got n-e-other ideas for this one?
+ Reply to Thread
Similar Threads
  1. Twisty Raods Directory
    By LinuxRacr in forum Motorsports: Keep it SAFE + On the track!
    Last Post: 11-14-2007, 06:20 PM
  2. CTC Motorsports Cruise for Kids.
    By LinuxRacr in forum Mazda Meets & Events!
    Last Post: 03-23-2004, 01:43 PM
  3. spoiler - who got one?
    By canada3 in forum MAZDASPEED3 & MAZDASPEED Axela (MZSPD3.com)
    Last Post: 02-06-2004, 11:50 AM
  4. WTB!Protege Trunk lid and/OR MSP/MP3 spoiler!
    By ForceFed in forum This Forum is READ ONLY!
    Last Post: 01-11-2004, 12:30 AM
  5. mp3 spoiler from mazdastuff.com
    By kting28 in forum 1999-2003 Third Gen Protegé (ProtegePower.com)
    Last Post: 10-15-2003, 11:45 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
