cbcbd said:It's actually pretty simple.
Going from memory:
-open hood
-look behind the light, you'll see the wires for the headlight - unplug the wires
-there is a rubbery ring around it, remove that - it pulls out semi easily
-you'll see the bulb's back in there, pull it out
replace doing the reverse.
traitorhound said:your missing the part about the tension clip. . .IIRC it was a b**** to get it off but you have to like push it in and down for it to unclip. .it may just be easier to unscrew it and just screw it back on
-rich
obzhagen said:The tension clip (the metal piece) is still whole. I believe it is just the plastic piece (the hinge, if you will) is what broke. So now there is nothing to give the tension clasp tension!
Demoniam - when you mention replacement, do you mean the whole assembly, like this: http://www.partstrain.com/products/AutoBody/Lights_(Front)/2003~MAZDA~PROTEGE5~4~2.0~PRO-5-002.html?sku=M100145
Hypothetically speaking, let's say a person (in a fit of rage) broke the tension clip holding in the passenger side headlight. Any suggestions for how to replace this? Looks like a piece of plastic may have broken off as well?
