Show your support and Donate!
+ Reply to Thread
Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 45
Thread: HOW-TO: Camera Mount
  1. #1
    Registered User
    Join Date
    Jan 2003
    Posts
    5,757
    Donated: 20$
    I don't feel like spending 100 bucks+ on an in-car camera mount, but it sure would be cool to get some Hwy9 footage!
    With this in mind, I've been searching the net for a cheaper solution, and this is what I found....Might be time for a lil' project this weekend.
    How to build an in-car camera mount
    Parts List
    3 - ¼ by 2½ inch bolts
    1 - ¼ by 1½ inch bolts
    3 - ¼ inch lock nuts
    7 - ¼ inch washers
    4 inches of plastic hose(sku#705230 at Home Depot)
    1 - 1"x48" box aluminum
    4 - Plastic end caps(Part #1189-6)*
    SLIK Compact Ball Head**
    Instructions
    1. Cut the box aluminum to the proper lengths. The short piece is 8 inches long and the long piece is 16 inches. At this point you can decide on the position of the camera in the car. If you want it more towards the center of the car just extend the length of the 16 inch piece. Then temporarily tape the two pieces of box aluminum together with electric tape. Mark the position for the three ¼ inch bolts, and drill the holes with a ¼ inch drill bit.
    2. Remove the electrical tape and bolt the two pieces of box
    aluminum together with the ¼ nuts, bolts and washers. After you have
    bolted it together, take your headrest and mark the location for the holes
    for the headrest posts to be drilled. Drill the holes first with a smaller drill bit. Then step the holes up to the final ½ inch size. Be careful while drilling these holes, since you are drilling in between the two pieces
    of box aluminum the drill bit will have tendency to bite into the aluminum.
    3. The next step is to drill the ¼ inch hole at the end of the longer box aluminum piece for the camera head mount.
    4. After you have finished drilling all the pieces you will need to go back and clean up all holes and cuts you made, especially the ½ inch holes for the headrest posts. Make sure there are no sharp areas left on any of the pieces. I used a dremel tool with a sander disk (it fits the ½ inch holes perfectly). You can also use a file or just a sheet of plain old sand paper. After you are finished sanding, cut a piece of the plastic tubing just wider than the box aluminum.
    5. The last step is to assemble all the pieces and do a test fit on the headrests. With all the bolts loose you should be able to slide the headrest posts into the rubber sleeves (it should be a little snug). If you can't, go back and sand a little off the ½ inch
    post holes. Retry. If everything fits, tighten the bolts down and make sure the mount is firmly attached to the headrest. That's it! You just built yourself a $35 camera mount for you car. Now go out and get some video!!!
  2. #2
    tra la la zmepro's Avatar
    Join Date
    May 2003
    Location
    California
    Posts
    1,945
    cool!
    MOCC MEMBER
    DISCLAIMER: All Mazda corporate employees, Mazda dealerships, Mazda service personnel or employees, family, friends, or acquaintances thereof: This in no way constitutes an admission or acknowledgement of tampering, modification, usage, or alteration of any vehicle in my possession or component thereof in such a fashion as to void, cancel, deny or otherwise refuse service on any service contracts, warrantees, or recall notices covering said vehicles. This and other posts submitted on this, or any Internet forum, under the screen names "zmepro" simply represent an attempt to gain acceptance from a peer group espousing cars of a high performance nature - especially those that have been altered to improve, enhance, or otherwise modify the automobile's natural characteristics. Any statements, claims, or graphical representations made that would constitute a violation of any contractual agreement are to be considered fictitious and not to be accepted in any court of law, or similar environment mediated for the purpose of dispute resolution.
  3. #3
    What "Lifestyle"? kcbhiw's Avatar
    Join Date
    Oct 2002
    Location
    Canton, GA
    Posts
    4,761
    Donated: $5
    ZoominMiata.com Moderator
    The only problem with that sort of mount is the excessive vibration that is received throughout the seat. I've also seen a mount setup that is tied to the rear "oh shit" handles. I'll post the link if I can find it.
    Good post, nonetheless.
    .....now, if only building a mount for the Miata was as easy.
    -Kevin
    2002.5 Protege 5 - The Daily
    1991 Tracer LTS - Turbocharged AWD GRM $2008 Challenger - Follow the build HERE!
    1990 Miata #1 - #80 CSP - '01 1.8L w/VVT Swap, Dedicated Racer
    1990 Miata #2 - #2 Turbocharged Grassroots Motorsports $2007 Challenger - BUILD
  4. #4
    jflo jflo's Avatar
    Join Date
    Sep 2003
    Location
    so cal
    Posts
    3,803
    hah...tell me about it. but that's cool...video footage of some fun runs
  5. #5
    Join Date
    Oct 2002
    Location
    Canton, GA
    Posts
    4,761
    Donated: $5
    There are times where I really wish I had a camera; those times where I've pulled some pretty sweet turns on course. Oh well.
  6. #6
    Mr. 3000 StarvingRussian's Avatar
    Join Date
    Apr 2003
    Location
    Gurnee, IL
    Posts
    3,051
    Illinois Moderator
    Thats really bad ass, my friend was thinking of making one that would go close to the ground, I'll have to show him this, we were also going to run a microphone from the camera under the hood so you could hear the engine. We did that once, but we also wanted video to go with it. Listen to it here.
    MAZDATEAM FAILBOAT CAPTAIN
  7. #7
    Registered User PaulMP3's Avatar
    Join Date
    Oct 2001
    Location
    Pineville, PA
    Posts
    5,240
    Donated: 20$
    good stuff natey... way to get clever.
    Performance Mods:Custom MSP turbo kit w/ ported manifold and downpipe, MPI piggyback,Tochigi Fugi LSD,Fidanza flywheel,ACT street clutch, SS clutch line, SS brake lines,awr motor mounts,JoeP MBC,2 1/2"exhaust with wagner mid pipe, MagnaFlow resonator, JIC canister, Random Technology cat,Greddy type S BOV,Rotora front rotors (slotted)brembo rear rotors,Hawk HPS pads,Spool springs,Kartboy Shifter/Bushing/Knob/exhaust hangers,1st grounding kit (blue)Sparkco wires(blue), mini oil catch can
    Electronics/Appearance Mods: UEGO widebando2 ,Greddy warning boost gauge, EGT, and oil pressure gauges, MSD knock senor w/ display, Blitz TT, Clear side marker,DaveB rings,DGM auto exe replica grill, Alpine 5 channel amp, blue coolant catch can
    Waiting to install: J&S safeguard, exhaust cutout
  8. #8
    dun poke me Dreeza's Avatar
    Join Date
    Jul 2003
    Location
    D-TOWN ...well, close to it...
    Posts
    2,450
    it doesnt work fool
    Mazda Team Member of the 'best sponsARED Kar evAR' (according to Ken)
    www.protegegarage.com
  9. #9
    Join Date
    Apr 2003
    Location
    Gurnee, IL
    Posts
    3,051
    Illinois Moderator
    Originally posted by Dreeza
    it doesnt work fool
    bullshit
    edit: it works fine, you have to left click on "here" then right click and save as in the thread.
  10. #10
    GenCoupe>Protegé5 pr5owner's Avatar
    Join Date
    May 2002
    Location
    Calgary
    Posts
    2,123
    Donated: 15$
    StarvingRussian your sig is a little bit scary
  11. #11
    On and On smithers_0990's Avatar
    Join Date
    Apr 2002
    Location
    Green Bay, WI
    Posts
    846
    The only problem with that mount is that most people don’t sit with the seat straight up. The way that one is positioned you would only see the sky.
    later
  12. #12
    MOCC Member PhatTrax's Avatar
    Join Date
    Sep 2003
    Location
    Ridgecrest, CA
    Posts
    323
    Quote Originally Posted by smithers_0990
    later
    mount it on the passenger seat and if someone sits there, kick them out
    2003 Pure White Protege5
    MOCC: Southern California
    http://www.cardomain.com/id/phattrax
  13. #13
    '04 Mazdaspeed MX-5 #1089 jersey_emt's Avatar
    Join Date
    Aug 2003
    Location
    Center of infinity
    Posts
    10,077
    Super Moderator
    I just bought this:
    www.stickypod.com
    The thing is absolutely incredible
    -Justin, Mazda Forums Supermoderator
    Should you have any questions or issues with anything here on Mazda Forums, please PM me.
    Mazda Forums Rules and Guidelines
    Mazda Team Mid-Atlantic: NY, NJ, PA, and DE Mazda Enthusiasts
  14. #14
    Join Date
    Oct 2002
    Location
    Canton, GA
    Posts
    4,761
    Donated: $5
    Quote Originally Posted by jersey_emt
    I just bought this:
    www.stickypod.com
    I really should invest in one of those. I shall call it...cone-cam, heh. I only have one video of me driving and that was at a track day at Road Atlanta. I need to either get one of those stickypods or rig something up so that I can analyze my driving when attending an auto-x.
  15. #15
    + enigMobile + enigM@'s Avatar
    Join Date
    Oct 2002
    Location
    New Jersey
    Posts
    1,685
    This is a good product too:
    http://www.clamperpod.com
    Just roll down the window and go to town.
    + e n i g M o b i l e +
+ Reply to Thread
Similar Threads
  1. affordable camera mount
    By enigM@ in forum Off Topic
    Last Post: 12-18-2003, 04:57 PM
  2. Where do you mount tweeter in the p5?
    By y0sky in forum Car Audio & Electronics
    Last Post: 12-05-2003, 01:11 AM
  3. Filling in motor mounts
    By carlos in forum Protegé 5 (Protege5.com)
    Last Post: 11-16-2003, 12:23 AM
  4. Ebay intake where to secure mount?
    By heuer17 in forum Protegé based Performance
    Last Post: 11-05-2003, 06:32 PM
  5. Mazdaspeed #3 Engine mount install..
    By LinuxRacr in forum Forced Induction Tech
    Last Post: 07-10-2003, 10:54 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
