Will a 17x8 Et20 5x120 rim fit on my Mazda Protege 5?
Is this a serious question?
1 off set way too low
2 lug pattern is 5x114.3 so clearly 5x120 will not fit. 30 seconds of reading would have answered this
This Forum gives more of a direct answer then searching 10 different answers on Google that"s the whole point of being here!There's this new invention called google use it. You will find any answer you need
Did I miss anything?
Ok thats helpful thanks but ive seen rims sizes that say 17x5x 114.3x E34. what the heck is an E-34 supposed to mean?Diameter- simple, how big the rims are
Width- how wide the rims are
Lug pattern- spacing inbetween bolt holes. Protgs use 5x114.3 or 4x100
Off set- how far the wheel will stick out. The higher the number the further inside the wheel well it will sit. +50 is normal offset for protgs +20 will push the wheel out and will rub. All cars are different and you need to research to see what you need
Center bore- how big the center hole is.
Ok thanks ill try attaching Mazda's247 at the end of it and hopefully that will get direct resultssidewall size- how big the sidewall is
Just gotta bust your balls man.
M2P503, google whatever it is you're looking for, then stick mazdas247 at the end of it. The forum's search function doesn't seem to work very well, but google can find what you're looking for. Chances are, it's already been answered. Just figured I'd throw that out there. Not trying to sound like a prick or anything.
