PCM Flash TSB
turboge
2003 & 2003.5 MAZDASPEED PROTEGE - HESITATION AND/OR INTERMITTENT STUMBLE UNDER ACCELERATION
APPLICABLE MODEL(S)/VINS
2003 and 2003.5 MAZDASPEED Protege
DESCRIPTION
A new calibration has been introduced to correct hesitation and/or intermittent stumble under acceleration. To correct this concern, reprogram the PCM of all MAZDASPEED Proteges using the following repair procedure.
NOTE: It is also recommended that the PCM reprogramming procedure be performed on all dealer stock of 2003 and 2003.5 MAZDASPEED Proteges prior to sale.
REPAIR PROCEDURE
Verify customer concern.
Using WDS B27.4 or later software, reprogram the PCM to the latest calibration (refer to "Calibration Information" table) by following the "Module Reprogramming" procedure.
NOTE:
Always update the WDS PTU first, then install the needed calibration file that WDS shows during PCM reprogramming. Go to "WDS Calibration" on ESI and download the "update" file. If the PTU is not updated to the latest WDS calibration level, the calibration file will not install into the PTU.
It is not necessary to remove any fuses or relays during PCM reprogramming when the WDS screen prompts you to do so. You may accidentally stop power to one of the PCM terminals and cause the PCM to be blanked, or you may receive error messages during the WDS reprogramming procedure.
WDS shows the calibration part numbers after programming the PCM.
Please be aware that PCM calibration part numbers and file names listed in any Service Bulletin may change due to future releases of WDS software, and additional revisions made to those calibrations for service related concerns.
When reprogramming a PCM, WDS will always display the "latest" calibration P/N available for that vehicle. If any calibration has been revised/updated to contain new information for a new service concern/issue, it will also contain all previously released calibrations.
When performing this procedure, if the WDS PTU is not docked and connected to 115V-120V, we recommend that a battery charger be installed on the vehicle battery and turned ON to a maximum charge of no more than 20 AMPS to keep the vehicle battery up to capacity. If you exceed 20 AMPS, it will damage the WDS PTU.
Place an "Authorized Modification" label (P/N 9999-95-AMDC-97) with the new calibration information near the Emission Control Information Label located on the hood or in the engine compartment.
Verify repair.
NOTE: After reprogramming a PCM, it is necessary to road test the vehicle to relearn KAM (Keep Alive Memory) strategy and verify no MIL illumination or DTC's are present.
CALIBRATION INFORMATION
New Calibration P/N
3ALU-12A650-MC
QOAP4C0
WARRANTY INFORMATION
NOTE: This information applies to verified customer complaints on vehicles covered under normal warranty. Refer to the SRT microfiche for warranty term information.
Warranty Type
A
Symptom Code
08
Damage Code
9W
Part Number Main Cause
****-18-88*
Quantity
Operation Number / Labor Hours:
XX575XRX / 0.8
OKAY.... I don't understand!!!!! Can someone please expain "FLASH" !!!!!
New to the board.... Production #291
JAY
Wouldn't a simple "yes' or "no" help instead of reading through a thousand posts that say "I got the flash done at such and such location and it's good or bad"?
Yes, that's the ECU Fix thread, but how long will it take to find the answer?! A "yes" or "no" takes 2 seconds if you know.
You should not need to print it, since it is now a TSB. All dealerships should have this in their release notes. If you do print it, please only print the text and refrain from any references to this website and my ID.
Yea my dealership is cool, they just call mazda na and ask them what to do since they are only a regular dealer, but they always do the work right and are really cool.
Latest posts
