Att>>> Spoolinmp3 and Chdesign - oil pan
Stou
I know it look like a weird question but did you have any problem to remove the oil pan to install new hose for the turbo.
We have removed all the bolts but it look glued very well and we are afraid to damage it while removing. The metal look very thin!
Is there any trick? :confused:
That's ok, I found it. It's a polyurethane glue, a very stong glue. To be removed, it need to be heated with an heat gun or a propane torch or the engine must be hot.
