I've run across the spoolin' and "flyin' miata" site and all of the specific details aren't listed on those sites.
Looks like the spoolin' kit uses a T3 turbo of some variety ?
I have a brand new T28 ball bearing turbo for a 2001 S15.
Turbo specs:
Compressor: T-28, 60 trim 60 mm BCI-1 compressor in T-04B housing
Turbine: Inco turbine wheel. Cast divider wall between turbine discharge and wastegate.
Center Section: Ball Bearing
Does anyone sell a kit or at least a manifold(t25 flanged) that would allow me to use this turbo on my P5 ?
This turbo is close to being the perfect size for the P5 IMO and lag would be almost non-existent.
My thoughts for a kit are as follows....
S15 Turbo - Internal Wastegate is already set at 7psi (perfect)
Front mount Intercooler and Piping, nice downpipe and exhaust, slighty larger injectors and a good engine management solution.
I'd like to see around 175-200whp with this combo.
What standalones have you guys had luck with Haltech , etc?
Thanks for any input
Turbo specs:
