JSCspeed.com - Your Source for IN STOCK Mazda Performance Parts!
+ Reply to Thread
Page 1 of 8 1 2 3 ... LastLast
Results 1 to 15 of 111
Thread: How To: Install In-Tank Fuel Pump
  1. #1
    Fast Shiftin' MoFo GOTZOOM?'s Avatar
    Join Date
    Oct 2002
    Location
    Fort Walton Beach
    Posts
    867
    HOW-TO: Install In-Tank Fuel Pump
    The fuel pump you need is a 94-97 Miata Walbro 255 LPH HP. P/N GSS342
    One of these is the stock Miata pump, and the other is the stock Protege pump.
    Step One: Remove Gas Cap. Flip drivers side rear seat forward.
    Step Two: Lift flap and remove 4 cover screws.
    Step Three: Unplug the two plugs.
    Step Four: You will need to remove this plug that I am holding from its holder that I am pointing to.
    Step Five: Now remove the Fuel Lines. This is tricky. Just use a small flat tip screw driver to lift each side of the green clip over the lip on the line.
    2002.5 P5- Installed: Spool Spec'd T3/T4 (*50 turbine *60 compressor *.63 AR *Stage 3 wheel) Spool Tubular Manifold v. 2.0 Spool Stage 3 Intercooler w/ SS pipes Custom 3" Cold Air Intake Rolling Hardware Street: 17” Konig Tantrums Nitto NeoGen 215/45 Ground Control Coilovers Rolling Hardware Drag: 15” Konig Traffik BF Goodrich G-Force Drag Radial 225/50/15 Transmission: Driveshaft Shop Racing Axles (prototypes) Clutchmaster Stage 2R Clutch Fidanza 7.5 lb Flywheel Kartboy short shifter, bushings and knob combo Exhaust: Greddy EVO Turbo-Back Electronics: Nordskog Digital Gauges: Boost, Fuel pressure, and Air/Fuel Meter installed in a 3 gauge full pillar gauge pod Greddy Profec B-spec II boost controller Greddy Turbo Timer UEGO Wideband kit with display Walbro 255 LPH In-Tank fuel pump Optima Red Top battery w/ Jeg battery relocation kit Future mods: Spool Stage 4 ECU (AKA: The Microtech)(On Order)
  2. #2
    Join Date
    Oct 2002
    Location
    Fort Walton Beach
    Posts
    867
    Step Six: Now remove the 8 screws that hold the unit on the fuel tank. IMPORTANT: Make sure you use a very good #2 screw driver on these screws. They are very tight and soft, and if you are not careful, you will strip them Pull the unit up and out, but not all the way, make sure the screen drains before tracking it across your interior.
    Step Seven: Unplug the fuel pump! If you dont, you will rip the wires out of the plug. Trust me, it will happen. Now that it is unplugged, remove the white clip and pull the fuel pump out. It will be a little tight getting it out, just pull on it.
    Step Eight: Either transfer the the screen to the new pump, or if you bought a new one, put it on the new pump. Do not use the one that comes with the walbro. It mounts in the wrong direction and will not pick up fuel. Remove the rubber sleeve off the old pump if it came out of the hole, and the white spacer and put them on the new pump. If the rubber sleeve isn't on the old pump, make sure it is still up in the fuel line. You dont have to take it out, as long as it is up in there your fine. Its what seal the nipple on the fuel pump going up into the fuel line.
    Step Nine: Put the new pump back into the holder and plug it in.
    Step Ten: Cut the bottom off of the white clip holder so that you have two clips for each side. I used a Dremel with a cutting disk.
    In the picture is the peice you are cutting off.
    Step Eleven: Put the two clips on and weave a zip tie thru them and around the fuel pump as in the picture. You may have to study these pictures to get it right. If its not done this way, the pump may come loose and fall into the tank while driving, and that wouldn't be good at all. Make sure to take a pair of pliers to pull the zip tie as tight as possible.
    Step Twelve: Make sure Fuel Pump is plugged in and reinstall everything. Happy Motoring.
  3. #3
    Join Date
    Oct 2002
    Location
    Fort Walton Beach
    Posts
    867
    Sorry guys, the site that host my pics turned them off for the rest of the day because I went over my bandwidth for the day. Bad Boy...BAD BOY! Check back again later and the pics should work.
  4. #4
    The First turbo MP3 spoolinmp3's Avatar
    Join Date
    Dec 2001
    Location
    lalaaa land
    Posts
    2,742
    Donated: $150
    Good Job, just for info I will move this to the HOW too section in a few days
  5. #5
    Registered User PaulMP3's Avatar
    Join Date
    Oct 2001
    Location
    Pineville, PA
    Posts
    5,240
    Donated: 20$
    good write up, this may come in handy.
    Performance Mods:Custom MSP turbo kit w/ ported manifold and downpipe, MPI piggyback,Tochigi Fugi LSD,Fidanza flywheel,ACT street clutch, SS clutch line, SS brake lines,awr motor mounts,JoeP MBC,2 1/2"exhaust with wagner mid pipe, MagnaFlow resonator, JIC canister, Random Technology cat,Greddy type S BOV,Rotora front rotors (slotted)brembo rear rotors,Hawk HPS pads,Spool springs,Kartboy Shifter/Bushing/Knob/exhaust hangers,1st grounding kit (blue)Sparkco wires(blue), mini oil catch can
    Electronics/Appearance Mods: UEGO widebando2 ,Greddy warning boost gauge, EGT, and oil pressure gauges, MSD knock senor w/ display, Blitz TT, Clear side marker,DaveB rings,DGM auto exe replica grill, Alpine 5 channel amp, blue coolant catch can
    Waiting to install: J&S safeguard, exhaust cutout
  6. #6
    That Guy flat_black's Avatar
    Join Date
    Jan 2003
    Location
    San Jose, CA
    Posts
    2,503
    Just out of curiosity, what are the differences in output between the two?
    - Eddie
    2002 Mazda Protege5
    2003 Suzuki SV650
    2004 Subaru WRX
  7. #7
    duMb TeaM
    Join Date
    Dec 2002
    Location
    OaHu, HaWaII
    Posts
    1,310
    how can you tell if theres a difference, do you need a fuel pressure gauge?
    duMb Ke0La
  8. #8
    Join Date
    Jan 2003
    Location
    San Jose, CA
    Posts
    2,503
    That'd do it just fine.
  9. #9
    yes, yes i do. dominoy2k1's Avatar
    Join Date
    Dec 2001
    Location
    houston, tx
    Posts
    5,211
    Donated: $20
    damn....what happened to the pics?.....
    Adam i will never forget you buddy...
  10. #10
    Join Date
    Oct 2002
    Location
    Fort Walton Beach
    Posts
    867
    Stupid villiage photo cancelled my account because I was directly linking to download videos. Who do you guys suggest for picture hosting?
  11. #11
    myother car is an auto :( azeli73's Avatar
    Join Date
    Aug 2002
    Location
    Mesa, Arizona
    Posts
    2,566
    Donated: $15
    something simple like yahoo should do it. or upload them here
  12. #12
    Join Date
    Dec 2001
    Location
    houston, tx
    Posts
    5,211
    Donated: $20
    yeah yahoo....cause i took mine apart but i dont know how to put new one in.....or just upload to the forum...
  13. #13
    Join Date
    Oct 2002
    Location
    Fort Walton Beach
    Posts
    867
    I've tried to upload them here, doesnt seem to work, unless I am doing something wrong. Maybe I will try Yahoo.
  14. #14
    Join Date
    Dec 2001
    Location
    houston, tx
    Posts
    5,211
    Donated: $20
    hey ummm try yahoo and just name them 1,2,3,4......etc...you can put em in the briefcase...
  15. #15
    Join Date
    Dec 2001
    Location
    houston, tx
    Posts
    5,211
    Donated: $20
    ummm...not to rush you or anything...but have you uploaded them yet....
+ Reply to Thread
Similar Threads
  1. fuel pump questions
    By ARunto in forum MSP Archives
    Last Post: 04-06-2003, 07:43 PM
  2. Fuel pump upgrade for use with turbo?
    By biknman in forum Forced Induction Tech
    Last Post: 10-15-2002, 10:47 AM
  3. fuel pump
    By rosendo192000 in forum Mazda MP3 (MazdaMP3.com)
    Last Post: 08-09-2002, 11:14 AM
  4. in tank fuel pumps
    By mazdamastertech in forum Protegé based Performance
    Last Post: 05-20-2002, 11:28 PM
  5. fuel pump and adj reg
    Last Post: 04-21-2002, 05:25 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
