Just got it in. Little bit of modification, but none worse than usual with Walbro install. Car stumbled on initial start up, but after about five minutes, computer must of compensated, and I now have a smooth 750 RPM idle. As with all Walbro's, pump noise is present, but at cruising speed, can't be heard over engine noise, ie. engine is louder. Fuel pressure gauge was reading 35PSI at Idle, now reads 40. Won't change much from stock without AFPR, or FMU as some of you call it. But when I get the Turbo and Microtech in, thats where it will count.
It is running rich, air/fuel meter is staying at 1.03, hope the microtech straightens that out.
