Thread size of oil pressure sender ??
turboboy
Hi guys, I was just wondering if anyone knows what the thread size is for the oil pressure sender ? I know this is where all of you turbo guys get your oil supply to feed the turbo. I'm putting together a turbo systems and I need to know the correct thread size so that I could buy the right T fittings. Thanks !
its a metric fitting pain in the butt to get fittings for. I just took a 1/8th NPT tap to mine and retapped it and now i can use any 1/8th NPT fitting in it.
According to the instructions from BEGI, the fitting is as follows:
OIL SENSOR ADPTR/FITNG 30215 INTO ENGINE BLOCK
You can get it from Bell Engineering These guys designed the FM protege Kits. You should also be able to get them from FM Protege with more availability.
Latest posts
