Set your timing with the old gears and belt, make reference marks on the cams and belt and one on the crank. Loosen the cam bolts. Then pull belt off, transfer marks to new belt. Pull cam gears off noting which slot the cams are in and transfer your marks on the cam gear to the msp gears. Line it all up and install timing belt. If you mark everything correctly it will all line up perfectly. Cam gears will move on you a hair but wont hurt anything as long as everything is lined up correctly
Sent from my SM-N920P using Tapatalk
