This is what mazda extranet says, sadly not much about what was fixed:
SERVICE ALERT Print
Date: 2016-04-01 Close
Service Alert No: SA-001260
Subject: MAZDA CONNECT SOFTWARE VERSION 55.00.760 AVAILABLE
Mazda Connect software version 55.00.760 is now available on MS3. Use this version for all MAZDA CONNECT updates, including OPEN SSP98 vehicles. If SSP98 is CLOSED, use TSB 09-022/15 to repair the vehicles.
Click on "IDS/Infotainment", then "Mazda Connect Updates" to download it. Update your USB drives according to the instructions in TSB 09-022/15.
Also make sure to select "All Files" for "Save as type:". If left as "Compressed (zipped) Folder," the file will be saved as a ".zip" no matter what you use as an extension.
ATTN: TECHNICIANS - Be sure to document the software version installed on the repair order and inform your Warranty Administrator to provide the information in the repair text of the warranty claim.
Mazda is working to make further improvements to the Mazda Connect Infotainment System software, and may issue future software updates to improve system operation and performance. Software version updates can be found on MS3.
