deepfriedsushi
- 95 Miata, 14 CX5 Touring FWD, 18 CX9 GT FWD
When I rotated my tires the other day, I noticed some dried leaves sticking out of the drain holes at the bottom of the wheel well. I thought this was normal and decided to remove the leaves to prevent a clog. However, leaves just kept coming out. I removed some of the clips to loosen the panels, but there is a push on clip holding it together and restricted full access. I didn't want to pull it out, so I just pulled back as much as I could and used my hands to scoop it all out.
This is what came out.
I checked the other side and found the same thing.
I've had the car for 3 years, don't really park the car under too many trees, but this is what came out. I've never cleaned out this area of the car before.
I never had a car that collected leaves like this, so I looked for the entry way of the leaves. Turns out the top of the fender in the engine bay and the base of the windshield are relatively open for leaves and debris to enter.
Top of the driver side fender from the engine compartment.
Rubber flap can be lifted up and exposes the backside of the fender and can be an entry way for debris.
The main entry way of debris is near the hinge. There is no guard there.
However, these 2 pieces try to limit the amount of debris, but it still makes it past. I've found plenty of leaves in this area.
I would suggest to you guys to check out your car for yourselves and unclog this area to prevent water retention and potential mold build up. But mainly...weight reduction!
When I have time, I'll see if I can find a way to make a simple little guard to limit debris from entering this opening.
