Transmission Problems
808MP5
Contributor
GT3076R Pro5
Long story short....
I lost 4th gear... It goes into the pocket but there's nothing there like I'm in neutral... I can put it in 4th now without pressing the clutch... The stick will stay in 4th gear position unless I push it out with or without the clutch being depressed
All other gears work fine except 4th...
Any ideas?
Does it make any noise? I would drain the fluid and check for debris, the gear could have stripped
