Hi All,
I did a search of this problem and the last comment posted was in 2012. There was no resolution nor diagnosis so I'm posting a new topic on this problem.
My tranny is fine except going from P to D on flat ground. The gear indicator says D but when I press the gas pedal nothing happens for two seconds. Then the gear changes and the car lunges forward. The delay seems to be variable and independent of temperature. Sometimes the delay is long and sometimes is short. I could always replicate the problem.
I've never driven a car with a delay this long.
Is this a design of the CX-5 or is there a defect in my car? I know I'm not the only one who's seeing the problem. But the last report of the same issue was in 2012! Thanks in advance.
Sent from my iPhone using Tapatalk
