Like a lot of us on here, I've been having the blue smoke on start up and it stops after about/around 30 seconds. I started with compression and leak down test and both were flawless. I replaced the OEM stem seals with Viton stem seals and triple checked everything went on perfect. I didn't mix up the intake and exhaust seals, they were all installed 100% correctly. For the first week after the fix I had no smoke and I thought all was well until I checked the oil. There was only 1 quart and it was pitch black. A new filter and 4 quarts of Rotella T6 later it starts smoking like hell like nothing was ever replaced. It doesn't smoke under boost or at all after start up so you'd think rings and turbo seals are good right? I'm just completely stumped at this point. Any input is greatly appreciated
