ffocused.
Alex Perrucci
2002 Sunlight Silver Protege ES
Suspension/Wheels:
Ksport Coilovers
AAC Adjustable Endlinks
Rotiform NUE 17x8 +30/OZ Monte Carlo 17x8 +37
Custom Motorsport Tech 10mm spacers (front)
ARP extended studs
Exterior:
Shaved trunk+Spare 03.5 MSP spoiler trunk
OEM Sedan front lip
EGR rear window visor
All red taillights
MSP Sideskirts
Morimoto Mini D2S 50w 4300k headlight retrofit
Interior:
CF gauge bezel
DaveB polished gauge rings
MOMO cf e-brake handle
Sunlight silver color matched trim
Engine:
Injen CAI
Corksport 60mm Power Series exhaust
AWR 88 duro front motor mount
Circuit Sports strut bar
CR3 dress up washers
CR3 radiator brackets
Hydra ADP
Wrinkle black vc w/ polished letters
Washer bottle delete
Cruise control delete
Bigsho
Sohan Ghosh
2007 Mazdaspeed3 GT
Suspension/Braking/Handling:
-Mazdaspeed Accessory Coilovers
-SPC Camber Arms
-Whiteline Adjustable Endlinks Front and Rear
-Hotchkis 32mm Front and Rear Sway Bars, rear is on stiffest setting
-OEM Mazda Brake Rotors
-Hawk HP+ Front and Rear Brake Pads
-17x8.5 +40 Enkei RPF1's with 245/40/17 BFG G-Force Sport Comp-2 tires
Engine/exhaust goodies:
-Autotech HPFP Internals
-HTP 3.5" Intake
-COBB Front Mount Intercooler (red piping and black core)
-Custom 2-piece 3" Catless Vband Downpipe with Top Portion Ceramic Coated
-Secondary O2 Sensor Delete
-Forge V1 Bypass Valve
-Mazdaspeed Accessory Catback Exhaust
-COBB AccessPort v3
-Cp-e 75 duro Rear Motor Mount
-JBR 80 duro Transmission Motor Mount
-CorkSport Passenger Motor Mount
-PnP Intake Manifold with VTCS Delete
-Sikky Manufacturing Thermal Insulating Intake Manifold Gasket
-James Barone Racing EGR Blockoff
-Kozmic Primary EGR Delete with Coolant Line Plug
-Kozmic Screamer Pipe
-Precision 5858CEA Journal Bearing Turbo with 4" Ported S Compressor and 2.5" Vband Outlet
-Precision 46mm External Wastegate
-Cp-e Vband Exhaust Manifold (Ceramic Coated)
-Cp-e Safe Seal Injector Seals
-James Barone Racing Stage 2 Oil Catch Can
-DIY Throttle Body Coolant Bypass
-James Barone Racing Thermal Insulating Throttle Body Gasket
-Bosch 3bar MAP sensor
-Grimmspeed 3 Port EBCS
-PTP 1950psi Rail Valve
-Tune by Realgib3
MSP#749
Justin Tomashek
2003.5 Mazdaspeed Protege (Blazing Yellow Mica)
Mods:
17x8 Rota Boosts
Drilled&Slotted Rotors w/ HAWK pads
Eibach Lowering Springs
HKS High-Power Exhaust
Universal Generic Rear Diffuser
Voltex Evo Style GT Wing
Innovate Gauges
GT28rs Turbo
Bumper Quick Releases
Rallyarmor Mudflaps
chiefmg
Mike Green
2000 Miata SE
Engine:
BRP MP62 supercharger w/intercooler, 10 psi of boost
EV14 550cc injectors
Walbro 250lph fuel pump
M-Tuned dual feed fuel rail w/stainless braided fuel lines
Cobalt 4-2-1 header w/949 Racing header blanket
Koyo 37mm radiator w/Lexan fan mount and two Spal fans
EUDM square top intake manifold
Coolant reroute with modified front thermostat housing
COP conversion
MSLabs MegaSquirt 2 (Enhanced) ECU
Innovate MTX-L wideband
ProSport electronic boost gauge
Powdercoated valve cover
Flyin' Miata 13.5 pound flywheel
949 Racing clutch
MiataRoadster short throw shifter w/Beatrush brass lower bushing
RoadsterSport midpipe
Brainstorm dual outlet muffler
Suzuki Cappucino washer bottle w/GarageStar wrinkle black cowl cover
IL Motorsports engine mounts
Chassis:
Ohlins DFV coilovers
Mazdaspeed rear diff mounts
Tuckin' 99 front fender braces
949 Racing front/rear braces
MSM front/stock rear sway bars
Cobalt three point front shock brace
Flyin' Miata frame rails w/butterfly brace
Beatrush PPF brace
Hard Dog Ace rollbar
Konig Lightspeed bronze, 15 X 7.5 w/Yokohama S/drives 205-50/15
Konig Flatout gold w/polished silver lip, 15 X 8 w/BFG Rival 205-50/15
DBA drilled/slotted rotors front/rear w/PowerSlot pads and braided stainless lines
RyokuRob tow hooks front/rear
Interior:
Recaro LX-C seats
KG Works woodgrain instrument surround
AWD brushed needle caps
revlimiter satin black vent rings
Nakamichi double DIN headunit with Bluetooth and removable faceplate
Clearwater speakers
IL Motorsports pedal covers
Exterior:
Factory ground effects
Home Depot front lip
MSM rear spoiler
Zoom Engineering fuel lid
Stock headlights modified w/The Retrofit Source HID conversion
Front/rear Mazda emblems painted body color
Project-G vent window vents
Body color taillight overlays
Hammo
Nathan H.
323 Astina SP20
Body/Styling
- AAC - Aggressive Auto Culture - Protg Bumper Brackets
- Autoexe Grill
- JDM Tail lights with Autoexe/MintBlue covers wrapped in CF Vinyl and Lamin-x Gunsmoke tint
- Front and Rear Bumpers Resprayed.
- MORIMOTO Mini V2 Bixenon Projector retrofit, Blacked out headlights (Matte Black)
- Mazda MSP Front lip
- Subaru 06-07 Chargespeed lip
- Mazda 3 Side skirt Extensions
- AutoExe Front Lip (sold)
- Lamin-x Yellow foglight tint (foglights not fitted)
Wheels/Tyres
- Mazda SP20 J48 16 X 6 +50 with 195 50
- Rays Mazdaspeed MS01 17x8.5 +40 with 235 40 17 Federal RS-R's
- Mitsubishi EVO 8 17X8 +38, 215 45 Kumoh Ecsta ku31. (sold)
- Mazda CX-7 Wheels 18 X 7.5 +50 with Falken 215 35 tyres (sold)
- AME Tracers 17X9 + 22 with Toyo Proxes 4 215 40 17 tyres (sold)
Suspension & Brakes
- Yellow Speed Racing Coilovers
- Autoexe 3 point front strut brace /w master cylinder stopper
- Autoexe rear strut brace
- Mazda Racingbeat 20mm Rear Sway Bar
- Pedders cut to lenght Rear endlinks.
- GT SPEC Lower controll arm brace
- GT SPEC V brace
- GT SPEC Ladder brace
- GT SPEC Reinforcement panel
- AutoExe 5 piece brace set
- AAC Lateral Link Kit
- Mazda RX7 FD3S 4 pot Front Calipers
- 320mm Slotted Rotors
- Custom Brackets for calipers
- Mazda MPS 6 Rear Callipers
- Mazda MPS 6 Rear Rotors 314mm
- Extended Handbrake cables by 210mm over standard.
- SuperPro Polyurethane Front LCA Bushes Front/Rear
- Mazda 626 (97) Front LCA Ball Joints
Interior/Entertainment
- CF Vinyl Mirror trim
- CF Vinyl Dash Trim
- Dash Mat
- Genuine SP20 Floor Mats
- Mazdaspeed Seat covers
- Mazdaspeed Carbon fiber gear knob
- Samsung Galaxy Note 8.0
- Pioneer single din head unit
- Pioneer Amp
- Kenwood 12" Sub in box
- Instrument Cluster Gauge Rings
- Dual Gauge Instrument Cluster shroud (Gauges to be fitted)
Engine/Engine Bay
- AWR Engine Mounts 70 Duro
- Autoexe Carbon Cold Air Intake
- CR3 Motorsports Radiator Brackets
- Hella Supertones
Exhaust System
- Perry axle back muffler
16vPete
Pete
2014 Mazda2 Sport
Wheels/Tires
- 15x7.5 Konig Lightspeeds
- 205/50/15 Dunlop DZ102s
Suspension
- Eibach Sport Springs
- Corksport Adjustable Shocks/Struts
- DDMWorks rear sway bar
Engine
- DDMWorks short ram intake
Exhaust
- Racing Beat axle back
loud3
Nathan O'Donnell
2014 Mazda3
Function
19x8.5 +45 Volk Racing by Rays Engineering forged G25 wheels (19.1lbs per)
235/35/19 Yokohama Advan Sport tires (21.2lbs per)
BC Racing BR type coilovers converted to ER type with inverted monotube dampers
Rolled Fenders without any flaring
Llumar Ceramic tint 20%
Form
Shaved rear hatch
flatlander937
Tony Mester
2011 Mazda2
Front Suspension
-Fabricated strut housings - Started with blank tubes just threaded at one end for the gland nut by TM Family Racing. They house Koni 8610-1436 Road Race strut cartridges(single adjustable). I made and welded all the brackets to them, the knuckle holes are made offset for additional camber adjustment(up to -3.5 total). They use coilover sleeves with a 2.5in adjustable lower spring perch, and Turner Motorsport upper spring seat originally meant for BMWs with Koni coilover conversions.
-Fabricated spherical bearing upper camber plates - utilize 5/8" New Hampshire Ball Bearing sphericals. By utilizing a custom made upper spacer, camber and caster are additionally adjustable at the strut tower without having to bore the hole in the strut tower(which would be illegal for STF class)
-550lbs Eibach 2.5in coilover springs, with some QA1 Torrington bearings to keep them from popping/pinging when turning
-Swaybar disconnected, plenty of roll stiffness without it
Rear Suspension
-Koni 8040-1419 Sport single adjustable rear shocks
-Eibach 450lb rear springs, made height adjustable via some Megan Racing adjustable spring seats originally meant for a Toyota Yaris
-DDM Works rear sway bar
Wheels/Tires
-TRM C1 15x7.5 +42 wheels(legal for STF class)
-Dunlop Direzza ZII Star Spec in 205/50R15
Misc Additional
-Fabricated rear motor mount, it utilizes off the shelf Energy Suspension bushings
-DDM Works solid shifter bushings
-Fabricated gas pedal extension - makes heel-toe shifting easier
PROPER
Deividas Liepa
2001 Mazda Protege5
JapanRacing JR-15 wheels, 8J ET35 front & 9J ET25 rear; bolted with JapanRacing hardened steel lug nuts; stretch on 215/40 Dunlop SP Sportmaxx tyres.
TA Technix coilovers.
Expell
Garett Ferguson
91 Mazda Miata
Suspension/Wheels:
Custom Work EWING III Curves 15x9/15x9.5
195/50 and 205/50 Dunlop Direzza Dz102 tires
Megan Street coilovers with custom swiftsprings 12k/10k
Pacomotorsports adjustable RUCA's
TC Sportline adjustable FUCA's
Interior/Exterior:
Bride BRIX I
Nardi shallow mahogany 360mm wheel
Nardi mahogany evolution knob
6.5" JL doorspeakers
Super adorable puppywithwings air-freshener
Eastcoastmiata shortshifter
Eastcoastmiata mirrors
OEM Rspec lipkit
Shaved trunk lid/ 3rd brakelight delete
Drivetrain/Engine
Torsen LSD
Poly diff bushings
1.8L Axles/driveshaft
garagestar engineliftplates
garagestar skid plate
