bubbaoriley
- Mazda Protege5
My 03 Mazda Protege5 has 4 codes coming up. I'm wondering if they are all related or separate issues. The biggest is P0303 cylinder 3 misfire. Pulled the plug and it looked burnt around the bottom as well as a little charred above the nut. Replaced it but it still feels rough on 10 mile test drive. Will update whether or not check engine light comes back on tomorrow. Coil pack is connected to 2 and 3 so I didn't think that it was gone because only 3 was misfiring. Is this correct? Other codes are P0031 heated oxygen sensor - bank 1 sensor 1. I assume this is a symptom of the misfire as this is the o2 sensor in the exhaust manifold. Is that a reasonable assumption? The other two I am not sure about. P0705 is the Transmission Range Switch. Is this just a part I should replace or is there a way to diagnose a problem with it? The last is P0660 actuator circuit malfunction. I honestly don't even really understand this one. I have read a lot about it but nothing specific on how to fix it or even really what this code is telling me. Any help and/or guidance would be appreciated. Limited mechanic ability but I have learned by doing. So if it is not something that has gone wrong in my wife's or my car, I might not know about it. Thanks for any help.
