Solid Snake
- 2010 LV TDCI Ford Focus
Hello guys, serious leak from MBSP when I put the old man's car up on the hoist, so I've removed sump and tried to remove the main bearing support plate, but there are two bolts behind the trans housing between the flywheel from what I have searched on this forum.
How does one separate the trans enough to get to those bolts?
Do I have to remove the whole trans, if so is there a process here that I can follow? I've never done a FWD box removal before.
Regards
Damo
Regards
Damo
