Anti sway bar
I have a box with 2 tens so I don't even have space for cargo , but cool I'm gonna look into them..
The link that Jackie chan sent me .. Are those good size for what I need ?
Sent from my iPhone using Tapatalk
I think so. They look beefier than the other ones posted. As long as the length you need falls into their span you should be good. You'd have to take endlinks off bar then hold sway up in place where you have clearance for how much your car is lowered then measure from tab on strut/coilover to eyelet on end of sway to know for sure.
Have you lowered your car ? When I adjusted my coilovers my rear end links ended up being to long , and I have 6 inch links.
My coilovers came with links in the front and they seem to be good
Yes I lowered the car, ~1 inch in the front and ~1.5 on the rear. But the rear was fine, there was a lot of space to adjust. I should note I'm still running the OEM sway bar and endlinks.
Hey guys so I installed my energy suspension adjustable rear end links. It's weird how they're both at the same length but the driver side has barely any clearance on the chassis. Over the speed bumps in my complex it ends up rubbing on the chassis.
Any solutions for this ? Both end links are at the same length
