1
125865
I know I know, this had been addressed many times but I'm really on the fence for what's wrong with this thing and seeking insight or ideas I haven't tried to nail down the actual problem.
The Car:
2003 Protege5 Wagon, 170k miles, manual trans, no mods
As far as I can tell original engine and trans but I bought it at 120k so who knows...
The Problem:
Smokes on cold starts, consuming about 2qts every 2-3 weeks. I drive about 10-12k a year, so that's probably 700 miles?
When I first got the car it didn't have a smoking problem and it started about a 9-10 months ago, and it's been getting slowly worse.
History:
One of the first things I did was a compression check and got 220 on the first, and 180 on the rest. Did it dry and wet with no significant difference.
After verifying with my meticulous friend that it doesn't smoke after startup I went ahead and did the valve stem seals with a Fel-Pro set but it didn't solve the problem. I did notice all the seals appeared to be the same (closely inspected any notifying markings on the seals and no difference). Since then I've learned there were apparently supposed to be different seals for intake and exhaust...
I've never had a chocolate milkshake, and it's manual so no strawberry either. PCV valve has been changed a couple times even after verifying it works with the suck and blow test. Ran some seafoam through the engine for a few hundred miles recently to see if there would be any change and it didn't seem to make a difference either direction. My last oil change I also put in a quart of lucas and changed the spark plugs to NGK v-power and now the thing smokes even worse!
The Smoke:
It's not white, but it is pretty light in color and has a stronger smell to it. I've seen coolant burn and it certainly ain't that puffy white cloud. I do seem to use up what's in the coolant reservoir in about 2-3 months so there may be some coolant leaking out or burning off slowly, but no drips on the ground. Only other possibility I could see for the smoke would be fuel but I don't have long cranks or gas fumes so that seems to be normal.
So, that's my deal, anyone have thoughts? Ideas? Diagnostics I haven't run? Anyone had that higher number 1 compression before?
The Car:
The Problem:
History:
The Smoke:
