hey guys, yesterday I got a check engine light, I put the scanner and it gave me a code (po302), its a cylinder 2 misfire, I changed the coils, and now my car doesn't start, please helppp
Did you get this issue sorted out? I have a P0303 (cylinder 3 misfire) and it's not caused by anything ignition related. I already tried different coil packs, wires, and plugs. I have yet to fix it
I'm having the same problem. Did the same thing. Still had the same error code and car idles like crap. Heard it also might be a bad fuel injector. I'm going to find a used injector at the junk yard tomorrow and see if that resolves the issue.
Mine has the same problem. The OEM NGK spark plugs are pregapped incorrectly. Here is the thread with all the info. This is essential to a working MSP.
Actually the OEM platinum plugs are gapped correctly, the replacement copper plugs you get at the store must be re-gapped bc autoparts stores don't stock the smaller gap plugs for whatever reason (lack of demand is my guess).
