In Memory of Mazdas247 Member "1338"
Page 1 of 2 12 LastLast
Results 1 to 15 of 18
Thread: Hood release cable replacement Protege5
  1. #1
    Registered Member SoonP5ismine's Avatar
    Donated: $44.49
    2003.5 MP5 Laser Blue Automatic (SOLD)
    Join Date
    Aug 2003
    Location
    Bloomfield, NJ
    Posts
    872
    I just ordered a new OEM one on eBay and I am just wondering if anyone here attempted to replace theirs on their own. Just looked through 14 pages of search results but it seems that no one talked about the cable replacement. Is it easy to do? What can I expect if I do it myself. To save $$ I try to do the work myself so if it can be done please give me some help. Thanks.
    Like new stock spare tire subwoofer/amp that came with my 2003.5 Protege 5.
    Subwoofer For Sale thread is http://www.mazdas247.com/forum/showt...98#post5307898
    Watch this Video: If You See Something Film Something!
  2. #2
    The Diagram Dude pcb's Avatar
    2002 mazda protege 5
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    2,256
  3. #3
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    2,256
    I won't be very impressed if you end up at the mechanic,...
  4. #4
    Donated: $44.49
    Join Date
    Aug 2003
    Location
    Bloomfield, NJ
    Posts
    872
    Thanks. I think the cable goes inside the fender right?
  5. #5
    Supercharged CDN P5 bikingpro5's Avatar
    CR3 Parts Rep
    PVB, Protegé, Canada & Marketplace Moderator
    03 Protege5
    Join Date
    Jan 2008
    Location
    NB, Canada
    Posts
    4,543
    Quote Originally Posted by SoonP5ismine View Post
    yes it does, you can see it in the drivers wheel well.
  6. #6
    Donated: $44.49
    Join Date
    Aug 2003
    Location
    Bloomfield, NJ
    Posts
    872
    So if I don't have to remove the fender I think I can do this myself without my mechanic.
  7. #7
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    2,256
    There was nothing mentioned about fender removal so you should be good.
    The only issue I can see for you is some kind of age related problem. Some thing could be rusted or seized then you strip a nut bolt or screw.
    After seeing that your from NJ (snow and salt I figure) and there are a bunch of smaller bolts you have to remove,... try to get some PB-Blaster on them,... try to get to the end of the thread where it rusts then swells then binds when removed then snaps. If a bolt seems like it's getting tighter as you remove it, thread it back in and spray it again.
    If the heads of any bolts look rusted keep in mind that all nuts and bolts on this car are 10 mm, 12 mm, 14 mm, 17, 19, and 21 for stock wheel lugs.
    The only exception I found was a 14 mm bolt that had rusted so bad that it lost material and a 13 mm fit. (and some nuts and bolts inside the blower motor, but that doesn't count.)
    I've had 20 minute jobs take all day.
  8. #8
    Registered Member ScratchNSniff's Avatar
    Way to Many
    Join Date
    Jan 2008
    Location
    Greer, SC
    Posts
    7,309
    Very easy job to do and extremely self explanatory...once you get in there and realize where the old cable routes...
  9. #9
    CR3 Parts Rep
    03 Protege5
    Join Date
    Jan 2008
    Location
    NB, Canada
    Posts
    4,543
    the bolts right up front are 10mm bolts, the rest can be removed from inside of the car as you are going to remove on long wire. I cut mine when i removed mine but i had no plans on ever running a hood latch again.
  10. #10
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    2,256
    That is one area on my car that still looks brand new,... but sometimes, you have to do stuff like this,...
  11. #11
    Way to Many
    Join Date
    Jan 2008
    Location
    Greer, SC
    Posts
    7,309
    Uhmmmm...lol...
  12. #12
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    2,256
    That's a chunk of rubber I jammed into the motor mount. It made a noticeable difference. Most productive twenty minutes I've spent on my car (next to the Colgate on my headlights)
  13. #13
    Way to Many
    Join Date
    Jan 2008
    Location
    Greer, SC
    Posts
    7,309
    Why not just get a new mount???
  14. #14
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    2,256
    I'm saving up my time effort and money for bigger things like when my ass falls through the floorboards,.. Almost every P5 around here is a rusty piece of crap,... Her glory days are over around here, it's kinda sad,... That was a quick and easy fix,.. no more engine flop.
  15. #15
    Registered Member lowlevel's Avatar
    2002 Mazda Protegé 5
    Join Date
    Mar 2013
    Location
    Milton, ON
    Posts
    261
    Quote Originally Posted by pcb View Post
    Until it falls out anyway
    213,377 km
Similar Threads
  1. E-brake cable replacement
    By gaubachis in forum Protege Wheels, Tires, Brakes & Suspension
    Last Post: 05-15-2011, 05:25 PM
  2. Replies: 17
    Last Post: 02-10-2011, 05:19 PM
  3. WTB: Hood release cable
    By vw2p5 in forum Completed Transactions
    Last Post: 12-18-2010, 05:03 PM
  4. Help needed with fuel door release cable!
    By pwright99 in forum Miata Lounge
    Last Post: 10-09-2010, 09:59 PM
  5. P5 Ebrake Cable Replacement
    By protege_03 in forum Protege5 Lounge
    Last Post: 10-23-2009, 10:22 PM
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
