Your Best Source for Genuine Mazda Parts!
Results 1 to 5 of 5
Thread: How to turn on fog lights when DRL lights are on??
  1. #1
    Registered Member
    mazda cx5
    Join Date
    Jan 2014
    Location
    southbay area, ca
    Posts
    38
    hello i noticed my fogs only come on if my headlights low beam is on when they are both set to auto. how do i make my fog lights come on when my DRLs are on or is this not a possibility?
    thank you
  2. #2
    Registered Member
    Join Date
    Sep 2013
    Location
    Anchorage, Alaska
    Posts
    25
    I think it's the law that factory fog lights are interlocked to only be able to come on with the low beams, and turn off with the high beams. So, I think you'll have to rewire, or at least jumper something, in order to make this work.
    Perhaps you could install the wiring harness from an aftermarket set of fog or driving lights, and power your fog lights that way, using another switch.
  3. #3
    Registered Member
    2013 CX-5 Touring
    Join Date
    Sep 2012
    Location
    Houston, TX
    Posts
    359
    Try the search function to find your answer more quickly. This has been discussed many times.
    The short answer is that you can't do it without custom wiring as mentioned above. Doesn't really make sense to me that you can't control them independently.
  4. #4
    Registered Member erhayes's Avatar
    Donated: $10
    Mazda CX-5 FWD Touring
    Join Date
    Jan 2007
    Location
    Cape Coral, FL.
    Posts
    2,149
    Since you have no tail lights when you have DRLs on, it probably considered a safety hasard to drive with fog lights and no tail lights in the fog. Fog light are to be used in fog only or in very smoky air.
  5. #5
    Registered Member
    2014 Mazda CX-5 GT AWD w/Tech
    Join Date
    Aug 2013
    Location
    Bloomington, Minnesota, USA
    Posts
    351
    I use mine in heavy snow. Lights the roadway better.
Similar Threads
  1. Replies: 1
    Last Post: 07-14-2014, 07:06 PM
  2. Turn Fog lights to DRL??
    By jimbosvt in forum Mazda6 Audio
    Last Post: 11-24-2011, 09:33 PM
  3. my lights won't turn off?
    By datoneguy in forum Global
    Last Post: 01-17-2007, 06:56 AM
  4. Replies: 1
    Last Post: 07-06-2003, 07:34 PM
  5. My lights won't turn off- HELP
    By For_Mica in forum MSP Archives
    Last Post: 06-24-2003, 02:52 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
