This is more like a teaser at this point, since I don't have many pics to share. But I wanted to post something.
Relevant specs:
AST 4100 coilover suspension
8kg/mm (~450lb/in) FR, 7kg/mm (~390lb/in) RR
6" spring FR + helper, 8" spring RR
Current ride height (change from stock): -1.2" FR, -1.0 RR
Kosei K4R 17x8 with Michelin Pilot Super Sport 225/45-17
Coilover suspension reduced unsprung weight by 16lbs (6lbs each FR corner, 2lbs each RR corner)
Wheels/Tires reduced unsprung weight by 18lbs (4.5lbs each corner)
Best pic I could get in the confines of my garage:
Nice chunky outer tread blocks:
I may go a bit lower in the future. Zero rubbing at current ride height, and clearances look really good - I could go a LOT lower without rubbing if I wanted, I think.
Haven't done a real alignment yet (no time), but a very (very) quick string setup says the moderate lowering hasn't affected things much. Keeping a very close eye on tire wear just in case.
The ride is excellent. Seriously, get rid of those Toyos, NOW. Seriously. I always found the most objectionable aspect of the stock vehicle's ride to be noise/harshness over small high frequency impacts like pavement seams, bridge expansion joints, or tar strips, and installing the AST suspension made this characteristic a bit worse (the rest of the ride motions and vehicle control were improved, it was just this aspect of the ride that I didn't like). The sharp sound and impact (like a 3 year old kicking your seat) really bugged me. I was afraid that the Michelins would be even worse yet – conventional wisdom says that a higher performance, lower profile (went from 16” to 17” wheels) tire will be less comfortable, but that was utterly and completely wrong. The Michelin Pilot Super Sports are seriously better in every way – turn-in, ultimate longitudinal grip, lateral grip, noise, ride comfort, everything. (Well, cost is probably the one category where the Toyos win but I’m not counting that). The sharp impacts are now a barely perceptible dull thud. I'm am very impressed with this tire and can barely recommend it enough.
I'll post some more detail and pictures in the future.
Relevant specs:
