Mazda of the Month | VOTE NOW for September!
  • Total voters
    39
  • Poll closed .
Status
Not open for further replies.
Antoine
Administrator
Welcome to the Official Mazdas247.com "Mazda of the Month" Contest!
* The MOTM is OPEN to ALL Mazdas! *
Please note the following rules & guidelines.
Your cooperation and participation would be greatly appreciated, thank you.
ENTRY RULES
* You must own the Mazda you are entering into the contest
* Any form of photo/image manipulation is not allowed except for adjusting and enhancing image color, contrast, tone and levels etc
* If you wish to enter two or more times in a row, you will need all new photos of your Mazda for each consecutive month entered
* If you become a MOTM winner, you may not enter the same Mazda again until at least 12 Months after the month you had won. However, if you own several Mazdas, you are welcome to enter those as well * Each Member may NOT enter more than one Mazda per MOTM contest * Previous MOTM winners who wish to enter again (after 12 months) must enter with all new photos of their winning Mazda
* Once you have entered (posted) your Mazda, you may not withdraw from the contest
* The MOTM contest & rules are subject to change in order to maintain a fair & fun environment for the Mazdas247.com Community
ENTRY REQUIREMENTS
* Each contestant must submit three single high-quality high-resolution images of their Mazda. One image must be of the exterior, another the engine bay and finally an interior shot. Compilation style shots (multiple images within a single image or picture size frame) are NOT ALLOWED!
Format
1. Username
2. Name
3. Model name + (Year)
4. ONLY 3 Images (one exterior + one engine bay + one interior shot) NO ATTACHMENTS PLEASE!
5. "Mod" List *Please make your list CLEAR & CONCISE!
Entry Tips
* Wash & Wax
* Clean your interior
* Clean your engine bay
* Choose an interesting location
* Choose a well lit location for photos
* Make sure your interior shot is clear and detailed
* Make sure your engine bay shot is clear and detailed
Example (Obviously, this is NOT my Mazda but for the sake of an interesting example):
Antoine
Antoine *
Mazda 767B (1989)
Performance Mods:
600hp 4Rotor
Exterior Mods:
Aero tuned for the track
Interior Mods:
ALL BUSINESS
Stereo Mods:
4Rotor
Awards Won:
Second in awesomeness only to the 787B
Recognition:
Raced at Le Mans...Helped lay the groundwork for the 787B which won Le Mans in 1991.
PRIZES
* A Mazdas247 T-Shirt and a pair of Mazdas247 Decals!
* Your Mazda showcased on the Mazdas247 Home Page!
* 5% off any Speedcircuit.net purchase made that month!
VOTING RULES
* All voters must have a postcount minimum of a 100 posts. The only exception to this rule is for MOTM participants who are also new members
* There is NO tolerance for PERSONAL CAMPAIGNING threads, posts, private messages (PMs), images or links (including signature and or image links). The creation of such ANYWHERE on or off the Internet including Mazdas247.com will result in immediate disqualification *If you are disqualified, your entry & poll listing WILL remain but your votes will be removed. Everyone will see that you broke the MOTM rules
* Creating GENERAL "Vote for the MOTM" threads and links is allowed and encouraged
GOOD LUCK AND HAVE FUN!
FrankenProbe
Dan
Rear-Wheel Drive 1997 Ford Probe GTS
Performance Mods:
  • KL 2.5L V6 engine (Stock)
  • Miata 5-speed transmission & adapter plate
  • Miata 4.10 rear end
  • 2-piece driveshaft
  • Miata SLA suspension front & rear (double wishbone)
  • 2,600 lb turnkey weight
  • custom fabricated one-off BIW (body in white) to accept Miata subframes, fuel tank
  • custom floor mounts to accept Miata seats
  • custom from subframe with KL motor mounts
  • Energy Suspensions poly diff mounts
  • custom mounted diff with adjustable pinion angle
  • custom oil filter relocation kit with larger filter
  • Miata manual steering rack
  • all sensors functional & correctly mounted
  • OEM cooling system with custom routing
  • 100% stock OEM computer, wiring and emissions equipment
  • hydraulic hood struts
  • pretty much assume that any structural sheetmetal on the car is custom made - I went through 2 10-lb spools of 0.030" welding wire
Exterior Mods:
  • 17x9.75 XXR 535 Wheels front & rear (untouched fenders)
  • 245/40/17 Front tires
  • 275/40/17 Rear Tires
  • Ground Control Coilovers
  • Energy Suspension full poly bushing set
  • G35 dual-tip muffler
Interior Mods:
  • ALL BUSINESS, no fuss:
  • Miata seats
  • Miata center console (including cupholders!)
Stereo Mods:
  • Eclipse head unit
Awards Won:
  • It won my heart...
Recognition:
  • The only car of its kind in the world
Xedosul
Claudiu Balaban
1997 Mazda Xedos 6 v6
Engine: 140 hp 2.0 v6 engine (stock)
Exterior mods: 2010 mazda3 wheels with 215/45/r17 bridgestone potenza tires
fully window tint
sprint blue paint colour this year
oem eleron
oem sun roof wind deflector
oem 93' back lights
Interior mods: RX-8 front seats and leds every where, leather armrest
Sound mods: blaupunkt stereo with pioneer speakers(back)and hertz dieci(front)
* Sorry for my bad english
Herblenny
Phil
1993 Mazda RX-7 TwinTurbo Touring Edition
Engine:
-Garfinkle Delrin Custom mounts
-Pettit Polished AST
-Koyo N-Flow Radiator
-Custom Carbon Fiber Cooling panel
-Fast acting Airtemp sensor
-Remote Start/pager/alarm/turbo timer
-BNR Stage 3 Twin Turbos
-Ported 13B-REW engine
-Custom Grounding kit
-polished Efini-Y pipe
-Polished upper intake manifold
-Polished 90mm Rotary Works Throttle body
-Polished Greddy elbow w/injector ports
-Apexi GT Spec FMIC
-Custom polished pipings By: BNRSupercars.com
-Constant tension T-blot clamps for IC pipings and Intakes.
-HKS seq. BOV
-HKS twinpower ignition amp
-RE-Amemiya SS Dual Dolphin Tip Catback
-SS Pettit DP
-Apexi PowerFC
-Mazdaspeed ignition wires
-FEED oil filler cap
-FEED coolant filler cap
-Added R1 Dual oil coolers
-Braille light battery
-Braille Verticle mounting kit
-FC Datalogit
-Unorthodox Alternator pulley (red)
-Unorthodox Power steering pulley(blue)
-Exedy Hyper Single Clutch Kit
-Simplified seq twin set up
-polished hardline intake pipes for secondary intake.
-Ported JDM Upper Intake manifold and polished by David Garfinkle. Also all the misc. vacuum ports have been welded shut and clean up and polished for cleaner look.
-Pettit Racing water pump pulley
-2 x 4 blade fan set up for better cooling
-HKS RS intake with KN filters
-Tweakit Racing tensioner pulley kit
Suspension:
-M2 launch kit
-FEED coilovers
-Racing Beat sway bar brace
-Racing Beat sway bars (front and rear)
-AutoEXE front brace
-Racing Brake Rear Brake kit with HP+ pad
-Hawk HP+ pads rear
-Newly sandblasted A-arms and other suspension parts
-SakeBomb AP Racing Big Brake Kit with Ferrado pads
-Braided SS brake lines
-Racing Beat sway bushings
-New Delrin bushings for all suspension parts
-Transmission brace
-Raceshop Rollbar
-Dragon's diff brace
-Rays Engineering Volk Racing TE37SL 18x9.5 Front and 18x10.5 Rear.
-Toyo R888s 255/35 front 295/30 rear
Interior & Stereo:
-Works Bell Short hub
-Works Bell Quick disconnect
-Works Bell hub lock
-Personal Steering wheel
-Converted Black interior - including, door panels, rear panels, head liner, seat belts, and black main carpet
-RZ floormats
-Rare moon roof interior cover
-JDM rear seats with panels, seat belts, and special rear carpet
-added R1 rear speaker pods for 7 speaker system
-Prosport boost, A/F, Fuel, Boost, and Oil temp gauges
-Prosport center speaker pod
-Bride Artis III Navi
-FEED Shift knob
-red leather stitching shift and ebrake boots
-LED interior lights
-RE steering column pod with 52mm Prosport boost gauge
-JKL Engineering Carbon Fiber Gauge cluster, hood AC panel, shifter,etc (Flattened look)
-JVC 7inch AV system
-New EL PowerFC commander and Gotham Racing PFC Commander holder
-RE-A speedo cluster gauge
-FEED Carbon fiber rear trunk add on.
-Base model hatch cover
-added OEM fog light switch to turn FEED HID driving lights
-Carbon look oem door step
Exterior:
-Mazdaspeed carbon hood
-AutoEXE carbon rear spoiler deck for the 99 spoiler
-One off Feed Carbon Gas door (Shine Auto)
-Feed Type 2R front bumper
-Feed Carbon fiber canards
-Feed Carbon Fiber side skirts
-Feed wide front fenders
-FEED rear wide flares
-Rotary Extreme hood dampers
-R-magic oil cooler ducts
-FEED front tow hook
-RE-Amemiya Pro Carbon rear diffuser
-Custom LED tail lights
-Custom rear bumper CF signal covers
-rare glass moon roof
-LED signal lights in FEED signals
-HID FEED Signal lights
-Spirit R fender badges
-Efini front are rear badges
-Carbon look rear bumper lights
-Carbon fiber FEED gas door (one off made)
-APR Carbon Fiber side Mirrors
-Custom front canard add on
-Carbon Cooling panel (custom, made by me)
-LED Front bumper strips
-R-Magic HID head lights
-FEED door handles
-Carbon Fiber back of the door handle covers.
-Back Off 3rd light flasher
-ShineAuto rear tail light lip
-Feed carbon Fiber bumper guard by Shine Auto
-Plasti Dip black exterior (DipYourCar.com)
ffocused.
Alex Perrucci
2002 Sunlight Silver Protege ES
Exterior Mods:
OEM Sedan Lip
2003.5 Mazdaspeed Protege Spoiler
17x8 OZ Racing Monte Carlo
Rear Window Visor
AAC Bumper Sag brackets
Lamin-x Yellow fogs
Interior:
Polished Dave B rings
CF Gauge Surround
MOMO E-brake handle and leather boot
Door handles and trim color matched Sunlight Silver
Suspension:
Ksport Kontrol Pro Coilovers
AAC Adjustable Endlinks
Engine:
Injen CAI
Valve Cover painted wrinkle black w/ polished letters
Mazdaspeed Miata Oil Cap
1.8 VC/Coil pack/Wire swap
Polished Mishimoto Coolant Can
Mazdaspeed Protege axle back
Ahh the fd is nice but I can't vote for cell phone pics or a non mazda (even though everything is minus the body)
Congratulations to Herblenny and thanks again everyone for entering the final month of MOTM 2.0...We're going to overhaul the MOTM and launch the new version in January 2014. I will post a link to the development thread here soon so please stay tuned, thanks!
Status
