Your Best Source for Genuine Mazda Parts!
Results 1 to 6 of 6
Thread: Fog Light Mod
  1. #1
    Registered Member
    2014 Mazda CX-5 Touring
    Join Date
    May 2013
    Location
    Indianapolis, IN
    Posts
    1
    Fog Light Mod
    Requesting a how-to procedure for being able to turn on the fog lights without the head lights on...
  2. #2
    Registered Member raden's Avatar
    2016 Mazda CX-5 GT AWD w/ Tech & i-Activ
    Join Date
    May 2012
    Location
    North NJ, USA
    Posts
    136
    I had independent fog lights in my Mazda 3. I would also like to know how to do this for the CX-5.
    Current:
    2016 Mazda CX-5 AWD GT w/ Tech Pkg & i-Activ (12/31/15-Present)
    Past:
    2013 Mazda CX-5 AWD GT w/ Tech Pkg (5/11/12-12/31/15)
    2007 Mazda 3 i-Touring (7/12/07-5/11/12)
    Follow me on Instagram: @fitwinesnob #CRUSHEVERYTHING
  3. #3
    Registered Member RedBaron's Avatar
    2014 CX-5 Touring
    Join Date
    May 2013
    Location
    Gaithersburg, MD
    Posts
    471
    I looked into this to see if there was an easy jumper you could do within the fuse box. Unfortunately, according to the schematic, there isn't. The drive to the Fog relay comes from the BCM, which performs the logic as to when to turn it on. You'd have to splice a wire directly from the switch in the steering column to the Fog relay in the fuse box, bypassing the BCM.
  4. #4
    Registered Member
    Join Date
    Jun 2008
    Posts
    10
    Boooooooooooooooo
  5. #5
    Registered Member IronMan0737's Avatar
    14.5 CX-5 GT AWD w/ Tech
    Join Date
    Mar 2014
    Location
    Pittsburgh, PA, US
    Posts
    118
    What about a BCM hack? Desolder and switch the fog with the parking light switch input wire(s)?
  6. #6
    Registered Member
    2014 Mazda cx-5
    Join Date
    Sep 2016
    Location
    Victoria BC Canada
    Posts
    3
    Fog Wiring
    Quote Originally Posted by IronMan0737 View Post
    Hey I just installed aftermarket fogs and originally just wired the switch to the battery but I kept forgetting them on. So I ended up wiring it to the marker light wire which doubles as turn signals, you just need to check which one is which. If I remember correctly I spliced into a yellow wire. There is 3-just strip them and troubleshoot. Now even if I forget the fogs on they turn off with the car as the markers do. Hope this helps a bit even tho you probably have a factory switch. I think if you disconnect the factory switch and hook up a separate relay system to power them and switch on-you can do it this way. Might be a little excessive though..This also involves removing the bumper and sliding out the headlight too, which is real easy once you do it, now I just put back enough plugs and bolts to hold it in place so I can always remove the bumper easy as i am constantly adding things underneath. Cheerrs
Similar Threads
  1. Tail light / fog light / amber light problem
    By THE Phen in forum Protege5 Lounge
    Last Post: 06-16-2013, 04:14 PM
  2. Mazda3 2007 - P0113 + TCS/DSC Light + Battery Light (On/Off)
    By cloves in forum Mazda3 Engine & Transmission
    Last Post: 04-21-2013, 11:50 PM
  3. Replies: 6
    Last Post: 07-13-2008, 09:05 AM
  4. mazdaspeed 3 tail light head light tint?
    By ByrdMan23 in forum MS3 Lounge
    Last Post: 10-24-2007, 06:43 AM
  5. Can the parking light made to be as bright as the turn light ?
    By skuekni in forum Mazda Tech & How-To
    Last Post: 10-26-2003, 11:42 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
