Your Best Source for Genuine Mazda Parts!
Results 1 to 5 of 5
Thread: cx5 first oil change
  1. #1
    Registered Member
    mazda cx5
    Join Date
    Jan 2013
    Location
    bayamom puerto rico
    Posts
    1
    I took my car to the dealership for the first oil change. They put conventional oil 5w-20. The dealer said that my car can use that oil due the tropical temperatures in Puerto Rico. Should I can go back to synthethic? The manual saids: OW-20 full syntherhic for USA and Canada. Any sugestions?
    Thanks
  2. #2
    Registered Member nizzy1115's Avatar
    2013 CX-5 Sport
    Join Date
    Apr 2012
    Location
    IL
    Posts
    765
    I would go back.
    2013 Black CX-5 Sport FWD Auto
    45% front 18% rear tints | NAV | Auto dimming homelink mirror | Polk DB351 in dash, Polk DB651 in front and rear | Door sills | OEM rubber floor mats and cargo tray | Coverking neosupreme fronts
  3. #3
    Registered Member
    2013 Mazda CX-5 Touring (moonroof/Bose)
    Join Date
    Jan 2013
    Location
    Florida
    Posts
    16
    I agree. Once you have synthetic oil in an engine, you should stick with synthetic. Also, you might want to request using the 0W-20 as well. The 5W-20 will probably reduce your fuel economy a bit since it will be slightly thicker than the 0W-20.
  4. #4
    Registered Member erhayes's Avatar
    Donated: $10
    Mazda CX-5 FWD Touring
    Join Date
    Jan 2007
    Location
    Cape Coral, FL.
    Posts
    2,198
    What does your manual recommend for Puerto Rico? I think 5w20 is just fine either with dino or synthetic. USA & Canada request lighter oil due to our fuel mileage requirements. You will never tell the difference between 5w 20 and 0w20 from my experience. Ed
  5. #5
    Registered Member CX-SV's Avatar
    Donated: $15
    2013 CX-5 GT AWD w/tech (Mar'12-Jul'14)
    Join Date
    Apr 2012
    Location
    northern CA
    Posts
    3,410
    Per owners manual:
    Puerto Rico owners should use SAE 5W-30 engine oil.
    Canada and Puerto Rico residents follow Schedule 2 (shorter oil change intervals).
Similar Threads
  1. To Change Or Not to Change, That Is The Question
    By fxpthl in forum Miata Lounge
    Last Post: 08-20-2011, 07:14 PM
  2. Sex change. Erm... tranny change question
    By sm4rtf00d in forum Protege5 Lounge
    Last Post: 10-15-2010, 05:40 PM
  3. Change guages, or change bulbs
    By mrskinnypete in forum Protege5 Lounge
    Last Post: 02-01-2008, 12:45 AM
  4. Should the noise level of my ride change when I change rims?
    By andytam in forum MS3 Wheels, Tires, Brakes & Suspension
    Last Post: 09-28-2007, 05:06 PM
  5. Camber Change = Toe Change?
    By nazgul350r in forum MSP Wheels, Tires, Brakes & Suspension
    Last Post: 03-07-2007, 09:42 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
