Show your support and Donate!
Results 1 to 4 of 4
Thread: Hydraulic Clutch Master/Slave Cylinder Failure
  1. #1
    Registered Member
    1990 Mazda 323 Protege
    Join Date
    Oct 2012
    Location
    West Columbia SC
    Posts
    3
    1990 Mazda 323 Protege.
    Quick question: The other day the clutch petal went to the floor, no engage. Replaced the master, bleed the sys -worked fine for a trip to the local store.. then failed again. Figuring it's the slave, I'm going to replace that even though neither part had/has fluid spilling from them. During the work I noticed that the rubber/cloth line from the reservoir to the master looks very worn; could it be possible that the hose is actually pulling air into the system causing it to loose pressure (therefore causing the complete system to fail)?
    Thanks....
  2. #2
    Registered Member
    Mazda 2002 BJ Astina 323 1.8 L
    Join Date
    May 2012
    Location
    Dubbo, New South Wales, Australia
    Posts
    96
    If that resevoir sharing hose was letting in air,..it would also let fluid leak out. Sounds like your clutch -slave cylinder, as you have also mentioned,..is out to lunch :-) Sometimes, the seal can be leaking quite badly, but the fluid stays in the cylinder or in the dust-boot.
    JJ
  3. #3
    Registered Member
    Join Date
    Oct 2012
    Location
    West Columbia SC
    Posts
    3
    Ahhh, this makes sense. I haven't been loosing any fluid.
    My thoughts behind the hose is that it's a supply line that is only really active when a vacuum is created (when the clutch petal is returning, the master is pulling fluid from the resev -hence while there is no pressure created for the fluid to leak out of the line (when simply sitting). Now, when that vacuum is created, air quite possibly could be getting sucked in through pin hole(s) of an old hose.
    I'm not certain as to the degree of air in the lines that would cause the system to fail completely or if it would fail at all... or simply cause the clutch petal to feel "spongy".
  4. #4
    Registered Member
    Join Date
    Oct 2012
    Location
    West Columbia SC
    Posts
    3
    BTW, for the record: IMO Hydraulic clutch systems are big waste of time, effort and money. I feel noooo difference between the comfort of the hyd clutch vs a cable setup. Wish there was a conversion
Similar Threads
  1. Clutch or Slave cylinder
    By 1fastms in forum MSP Problems
    Last Post: 12-11-2012, 09:51 AM
  2. Clutch Slave Cylinder (dunno)
    By Travizzle21 in forum Miata Lounge
    Last Post: 01-07-2009, 01:33 AM
  3. Question about clutch slave cylinder
    By Wes V in forum Protege5 Lounge
    Last Post: 12-13-2007, 11:12 AM
  4. MS3 Clutch Slave Cylinder Problem
    By CRS in forum MS3 Engine & Transmission
    Last Post: 04-09-2007, 03:36 PM
  5. clutch master and slave cylinder
    By hi-perf in forum Off Topic
    Last Post: 01-02-2004, 03:06 PM
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
