Battery Light ON but Alternator is Charging?
Had the codes checked today, no IAT code. I believe the pins on the connector were loose, so I bent them back and its good to go.
Having the SAME/SIMILAR problem. Which pins on which connector are you referring to?
MAF? alternator? PCM? Something else?
Did you ever fix the problem? Did it ever come back?
