VersaTuner - tuning software for Mazdas
Results 1 to 12 of 12
Thread: Oxygen Sensor Change with Photos
  1. #1
    Registered Member
    2002 Mazda Protege5
    Join Date
    Mar 2011
    Location
    New york
    Posts
    12
    Thumbs up Oxygen Sensor Change with Photos
    First I'd like to point out that I was able to get the Upstream OEM Denso for $30.00 USD Shipped. I've been using DENSO for years and I can swear by them.
    Here is the link for anyone intrested:
    http://www.ebay.com/itm/380448114964...S:3160&vxp=mtr
    Now for the fun part.
    Disconnect Battery Cable - This way the computer will reset itself to accomodate the new sensor.
    Remove air intake snorkel:
    Unplug to old sensor. Mine did not want to disconnect so I use a small flat blade screw driver.
    Remove the heat sheild. 10mm bolts. Three on top one on bottom of sheild
    Remove Sensor with sensor socket. I used a 7/8 wrench and had no problems:
    Removed Sensor:
    Compare Sensors:
    Compare Plugs:
    Re-install everything in reverse order
    I applied Dielectric grease as a personal preference:
    I put grease in and out of plug:
    New Sensor installed:
    Sensor Plugged in:
    I left my heat sheild off as it was rusted out till I find a repleacement. I re-installed the air intake snorkel back on:
    Re-connected the battery and started the the car right up. Car feels like it's pulling harder but that may be just me.
    I also cleaned the Mass Sensor, Throttle Body, EGR valve and changed the plugs.
    Hope this helps anyone out there looking to do this.
    This is very simple as long as the old sensor is not seized in.
    Vic Vega
    2002 P5
  2. #2
    Registered Member tweety2300's Avatar
    2001 mazda protege mp3
    Join Date
    Sep 2010
    Location
    virginia
    Posts
    5,803
    Couple of things
    Pics don't work
    I would highly suggest using the o2 socket as you can rent it at autozone for free and it will garunteed you won't strip it off.
  3. #3
    Registered Member
    Join Date
    Sep 2009
    Location
    Montreal, Quebec
    Posts
    2,624
    Good write-up.
    In addition to what tweety2300 said, I wouldn't recommend putting dielectric grease on the contacts, it might give you continuity problems in the future. Rub it on the outside of the connector to ease installation/removal but that's it.
  4. #4
    ~Rico~ RicoP5's Avatar
    Donated: $5
    2002 Mazda Protege 5, red
    Join Date
    Apr 2007
    Location
    San Antonio, Texas
    Posts
    4,009
    I know the downstream one I replaced it was that long but the upstream one wire is. It that long ? Y is the one u got so long ? Makes me think it's a downstream one? Jw because I need to replace my upstream one and would hate to order the wrong one ..
    Sedan front end,white rx8 wheels ,aac 13' brakes kit(reserved), NGR hub with quick release and sparco wheel, system, hids, exhaust, headers, Injen cold air intake, adjustable rear endlinks,moog front end links, engine bay washer dress up kit, shorty antenna, interior leds,rear hatch led, braided clutch line, jdm tailights, wink mirror,sickspeed horns, CF brake handle, redlinegoods shift boot, cr3 rad brackets. coil sleeves,
    My P5 build thread
    http://www.mazdas247.com/forum/showt...ke-one-too-lol
    emergency part out!
    http://www.mazdas247.com/forum/showt...ajor-emergency
  5. #5
    Registered Member
    2002 Mazda Protege5
    Join Date
    Mar 2011
    Location
    New york
    Posts
    12
    Pictures fixed. Thanks for the tip on the grease. I've never had a problem before but I will keep an eye out.
  6. #6
    Registered Member
    2002 Mazda Protege5
    Join Date
    Mar 2011
    Location
    New york
    Posts
    12
    I double checked the part number at the local parts store and online and made sure it was an upstream before ordering it.
  7. #7
    Registered Member
    Join Date
    Sep 2009
    Location
    Montreal, Quebec
    Posts
    2,624
    The Bosch one I bought also had a very long wire. There's probably another car that uses the same connector but with a longer wire...
  8. #8
    Donated: $5
    Join Date
    Apr 2007
    Location
    San Antonio, Texas
    Posts
    4,009
    Sounds good thx
  9. #9
    Registered Member
    Mazda 2002 BJ Astina 323 1.8 L
    Join Date
    May 2012
    Location
    Dubbo, New South Wales, Australia
    Posts
    96
    Dielectric grease is non-conductive and is designed for eliminating air-pockets between semi-conductors and heat-sinks. In some cars which have a single wire, the thread needs to be a good connection to the exhaust. In some cars, they use a heating element which may also need a good earth via the threads. Copper impregnated grease maintains a good electrical connection and stops seizing.
    JJ
  10. #10
    Registered Member CR3 Motorsports's Avatar
    Join Date
    Dec 2011
    Location
    USA
    Posts
    1,130
    Would you happen to have an updated link to the Denso o2 sensor on Ebay? I couldnt find it at $30.
  11. #11
    The Diagram Dude pcb's Avatar
    2002 mazda protege 5
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    2,298
    Rockauto's got the Denso (more money though)
  12. #12
    Registered Member rit14623's Avatar
    2002 Mazda Protege5
    Join Date
    Aug 2005
    Location
    Richmond, VA
    Posts
    415
    Never noticed this thread until now. I see the Denso's O2 sensor tip is a bit narrower than the other one, maybe Bosch.
    I couldn't do the spark-plug non-fouler thing because the Bosch O2 sensor didn't fit through after drilling it out with a 1/2" drill bit.
Similar Threads
  1. WTB oxygen sensor
    By MaxRX7 in forum Completed Transactions
    Last Post: 02-06-2011, 08:45 AM
  2. FS: MS6 OEM Oxygen Sensor
    By piotrekkb in forum Completed Transactions
    Last Post: 03-29-2010, 09:39 PM
  3. Oxygen Sensor
    By gapeachsp5 in forum Protege5 Lounge
    Last Post: 04-13-2005, 01:04 PM
  4. Oxygen sensor??
    By Timothyap5vm in forum Protege Performance
    Last Post: 09-04-2004, 11:06 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
