Your Best Source for Genuine Mazda Parts!
Results 1 to 10 of 10
Thread: When do I need to replace the timing belt?
  1. #1
    Registered Member
    2000 mazda protege
    Join Date
    Jul 2012
    Location
    Indianapolis
    Posts
    2
    I have a 2000 Protege with a 2.0 and was told by the previous owner that it needed a timing belt. Where or how the owner got that info is unknown. I am a dodge guy and have parked the hemi for a more affordable ride. So I am unfamiliar with the mazda's. The 2.0 is an interference engine and dont want this thing to just up and go on me one day. Yet I dont want to pull it out of service if it doesnt need it. Can you guys get me up to speed on these engines (and cars). What are the quirks about these cars? Anything important I should be aware of and look for?
  2. #2
    Registered Member
    2001 Mazda Protege ES 2.0
    Join Date
    Mar 2011
    Location
    Coral Springs, Florida
    Posts
    119
    I think it is non interference. I also think that maybe about 100k you should start to think about it; and the water pump.
  3. #3
    Registered Member IshSonP5's Avatar
    Donated: $5
    2003.5 P5T
    Join Date
    Dec 2011
    Location
    Palmdale, Cali
    Posts
    729
    at about 90k you should do the timing belt and water pump. other than that the usual maintenance and keeping up with it the car shouldn't have any problems. They are pretty reliable when still stock.
    2003.5 MP5 // Finally Boosted
  4. #4
    Registered Member
    2000 mazda protege
    Join Date
    Jul 2012
    Location
    Indianapolis
    Posts
    2
    Lol, ok. It has over 133,000 on the engine. So I guess it is time for the timing belt and water pump. Is 90,000 the interval for changing the timing belt? Or is it just a junk chain from the factory and needs to be replaced that early?
  5. #5
    Wiggity-Wack-O-Tack njaremka's Avatar
    Donated: $0.61
    2011 MX5 GT
    Join Date
    Nov 2001
    Location
    Glastonbury, CT
    Posts
    6,854
    owners manual says to check at 60k, replace at 105k.
    engine is NON-interference.
    Nik
    2011 Black MX-5 GT
  6. #6
    Registered Member concept's Avatar
    2014 Mazda3 S GT auto, 2008 MX5 6-speed
    Join Date
    Mar 2009
    Location
    San Diego
    Posts
    1,043
    90,000 mile intervals are fairly common for belts (not chains). If yours has never been changed, you should get it done (or do it, yourself), soon.You might want to "turkey-baste" the powersteering fluid and change the radiator coolant and brake fluid. If you have an auto tranny, change its fluid as well. Heck, if you have a manual tranny, do the same. That way, you won't have to worry about that stuff for quite a while.
    2014 3S GT, Deep Crystal Blue, Eibach Pro-Kit, Enkei PF01s, Koni Sports
    2008 MX-5 Touring (Mazdaspeed CAI, HIDs, Progress/Koni Sports/Racing Beat sways, Magnaflow)
    2002 Protege ES (no mods. but among the best-handling stock cars I've ever driven)
  7. #7
    Registered Member Mazda Pro's Avatar
    2003 Mazdaspeed Protege 2.0 Turbo
    Join Date
    Aug 2012
    Location
    Toms River
    Posts
    90
    Blog Entries
    2
    most people say 100k i change at 90k and water pump. other then that maintain it you'll be fine. like this guy up top said change the trans and break fluid while ur at it. american to a jap cars a good move in my mind then again it is for your wife.
  8. #8
    Registered Member tweety2300's Avatar
    2001 mazda protege mp3
    Join Date
    Sep 2010
    Location
    virginia
    Posts
    5,803
    I changed mine at 150k stock water pump is still going.
    Also if the trans fluid hasn't been changed in an auto with over 100k miles do not change it.
    I'm a little confused as to how you have a 2000 protege with a 2.0, the 2.0 didn't come out till 2001 the 99-00 only had the 1.6 or 1.8
  9. #9
    Registered Member
    2002 PROTEGE 5
    Join Date
    Mar 2013
    Location
    Ottawa
    Posts
    2
    Quote Originally Posted by tweety2300 View Post
    I'm a little confused, I am 110k miles and auto tranny fluid was never changed.... Should I do it or will it make it worse ?
  10. #10
    Join Date
    Mar 2009
    Location
    San Diego
    Posts
    1,043
    If you ignore it, your transmission will fail prematurely. What you may not want to do is have the trans fluid flushed. A simple drain and fill (2 times within 1 month) shouldn't cause any problems but may very well extend the life of your fluid. Check your owner's manual for recommended change intervals.
Similar Threads
  1. When to replace timing belt?
    By cs1992 in forum Protege Performance
    Last Post: 11-24-2012, 08:46 PM
  2. What else to replace while replacing Timing Belt ?
    By dd123 in forum Protege5 Lounge
    Last Post: 05-17-2012, 01:10 AM
  3. After Timing Belt Install=Loss of Timing/Stalling
    By speedin in forum MSP Problems
    Last Post: 04-10-2012, 05:29 PM
  4. timing belt change - timing marks
    By c4racer in forum Protege5 Lounge
    Last Post: 02-24-2010, 08:57 AM
  5. Timing Belt replace....
    By Earful in forum MSP Performance
    Last Post: 12-30-2006, 08:21 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
