Shop at EdgeAutosport.com to make your Mazda Go Fast AND Look Good!
Results 1 to 3 of 3
Thread: ABS and parking brake lights on
  1. #1
    Registered User
    2003 mazda protege es
    Join Date
    Jul 2012
    Location
    Canada
    Posts
    1
    Items for Sale
    Hello,
    My 2003 Protege ES 2.0 L has the ABS and parking brake lights on all the time. Had the codes checked and came up with this:
    • C1186: Antilock brake system power relay open circuit
    • C1175: LR WSS input circuit malfunction
    • C1233: LF WSS input missing signal
    • C1236: LR WSS input missing signal
    Any ideas for where i could start to identify the problems? I'm trying to keep my costs down as much as possible.
    Thanks
  2. #2
    Registered User
    2002 Mazda Protege ES auto, 1989 Mazda MX6 GT auto
    Join Date
    Mar 2009
    Location
    San Diego
    Posts
    138
    Items for Sale
    It looks like there is a connector that is disconnected. See if you can find the brake relay and check all connections. Also, see if there are any breaks in the cable. My son's air conditioning harness wiring was getting cut by a rabbit that liked to live under the hood.
    2002 Protege ES (no mods)
    1989 MX6 GT (Eibach Pro Kit, Magnaflow muffler/cat with 2.25" pipes, Konig, Britelite 16s, chipped/double boost, Triple pod with GlowShift gauges)
    1997 Honda Civic CX "The Hatch" (Eibach suspension, AEM V2, Magnaflows, pillar pod tach (Glowshift), Black Racing Pro 16s)
  3. #3
    Registered User
    2002 Protege ES; 2004 MPV ES
    Join Date
    Sep 2012
    Location
    Toronto
    Posts
    1
    Items for Sale
    My 2002 Protege ES also has the ABS and brake lights on. It started intermittently, but now constant. Seems like this is a common problem, as a little google search did find many people reporting this problem.
    The mechanic said will need to change the ABS sensor/module and is looking into the pricing.
Similar Threads
  1. DSC, Parking brake, ABS and "traction" lights on....
    By wannabe in forum MS6 Engine, Transmission & Drivetrain
    Last Post: 06-03-2012, 05:33 PM
  2. Replies: 3
    Last Post: 03-08-2009, 12:04 AM
  3. Linking parking lights to fog lights on 06 Mazdaspeed6
    By USAFVMI08 in forum Mazda6 Accessories & Appearance
    Last Post: 08-27-2008, 11:03 AM
  4. Changed rear brake pads; parking brake woes
    By vkeks in forum Mazda Protege 5 (Protege5.com)
    Last Post: 12-26-2007, 01:54 AM
  5. 03 P5 ABS/Parking brake idiot lights
    By dman in forum Mazda Protege 5 (Protege5.com)
    Last Post: 06-29-2007, 08:35 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
