Hi everyone,
We are having some issues with our Mazda 3. Code scanner is giving us a P0113 (IAT High Voltage) plus the TCS/DSC light comes on at the same time. The battery light also is coming on and off. the MAF/IAT was replaced about 8 months ago. Back at that point the car had hesitation and was shutting off. Mechanic at the time swapped it for a re-manufactured MAF. I disconnected the battery today and I took out the MAF/IAT and cleaned it out. It was actually pretty clean. I checked the connectors coming out of the MAF and the pin inside, everything was pretty clean looking and I didnt see any corrosion. Reassembled everything and did the start for a minute and shut off relearn process when done. Went for a ride and about 20 minutes later check engine and TCS/DSC came back on.
Anyone have any thoughts on what could be causing all these things to occur? One of the mechanics who took a look quickly at the car said it could be the alternator starting to fail. The car has 65k on it.
