Your Best Source for Genuine Mazda Parts!
Page 1 of 2 12 LastLast
Results 1 to 15 of 21
Thread: PR5 cranks but won't start
  1. #1
    Registered Member spifco's Avatar
    02 Mazda Protege5
    Join Date
    Jul 2012
    Location
    Pflugerville, TX
    Posts
    7
    Angry PR5 cranks but won't start
    So I'd like to begin with sup ya'll I'm new to the forum I've only looked at these things never really joined or posted to any of them.
    I recently bought an '02 protege5 with 155000 miles on it it had a blown motor, so I swapped the engine, but it won't start, I double checked all connections everything is in its place. The engine cranks with a slight whine at first then continues kick'n, but it will not start the timing belt is good, all fluids are topped off and I've got power to everything.
    Q?: What else could be the cause for it not to start?
    Make: Mazda
    Model: Protege5
    Engine: 2.0L 16 valve DOHC off an 03 Protege with about 90,000 miles
    Color: Lellow (Yellow)
  2. #2
    Registered Member zhy's Avatar
    I aint even mad!
    Join Date
    Jan 2012
    Location
    Montreal, Canada
    Posts
    653
    Check your fuel pressure.
    also check for corroded coilpacks and change your spark plugs
    that shuold help!
    Follow my build/progress thread here!
    STICKY How-to by me : Custom LED cluster here!
  3. #3
    Registered Member tweety2300's Avatar
    2001 mazda protege mp3
    Join Date
    Sep 2010
    Location
    virginia
    Posts
    5,803
    +1 gotta make sure it's getting fuel and spark before anything else
  4. #4
    02 Mazda Protege5
    Join Date
    Jul 2012
    Location
    Pflugerville, TX
    Posts
    7
    okay so I checked everything all over again. took the liberty to change the timing belt and triple check the wiring, I do have fuel pressure and i do have spark, but no dice. I think I may have flooded the engine with gas cause man oh man does it wreak of fuel. I had new plugs on the car and put the old ones back in. I did however notice a bit of moisture on one of the plugs I pulled out. What could caused that? I looked in the plug chamber and could not see anything.
  5. #5
    Join Date
    Sep 2010
    Location
    virginia
    Posts
    5,803
    Gas
  6. #6
    02 Mazda Protege5
    Join Date
    Jul 2012
    Location
    Pflugerville, TX
    Posts
    7
    So here Is a vid of what it's sounds like. I hope it helps.
  7. #7
    Registered Member wallabe's Avatar
    2002 Mazda Protege5
    Join Date
    May 2011
    Location
    Memphis
    Posts
    164
    Hope this helps
  8. #8
    Join Date
    Sep 2010
    Location
    virginia
    Posts
    5,803
    To me it sounds like a timing issue
  9. #9
    02 Mazda Protege5
    Join Date
    Jul 2012
    Location
    Pflugerville, TX
    Posts
    7
    Engine has bad head gasket water is leaking into combustion chamber. Oh well on to head gasket.
  10. #10
    Registered Member javestack's Avatar
    2006 Subaru Impreza 2.5i
    Join Date
    Jul 2012
    Location
    Milwuakee Area, Wisconsin
    Posts
    12
    Quote Originally Posted by spifco View Post
    I was about to say check compression when I read this. Makes sense.
    Automatic transmission are mechanical Tyranny.
    ˇViva la Revolución!
    "You've been driving by yourself all these years. You've never competed with anyone.
    Remember, don't pay attention to the competition itself. Ignore other racers. The one you need to beat is yourself."
    -Bunta Fujiwara (aka: Tofu Man)
  11. #11
    02 Mazda Protege5
    Join Date
    Jul 2012
    Location
    Pflugerville, TX
    Posts
    7
    So I've swapped out the gasket and cleaned the head, ran some oil through the engine to remove any water left behind. Now I seem to have a rough start and a quick shut off unless idle high. Should I run some sea foam through the crank case to assist the water evaporation and cylinder lubrication.
    UNO PARA TODOS Y NADA PARA UNO.
    - Los Zapatistas
  12. #12
    Join Date
    Jul 2012
    Location
    Posts
    12
    Antifreeze being burned with the fuel while the head gasket was going could have damaged your O2 sensor causing the EFI to run an incorrect amount of fuel, therefore rough start and incorrect idle speed.
    Are you still tripping your CEL? If so, you need to get it read somehow. That will tell you a lot.
  13. #13
    2002 Mazda Protege5
    Join Date
    May 2011
    Location
    Memphis
    Posts
    164
    Sounds like the motor is getting too much air. Check your air intake. You can get a $30 ODB II reader from Autozone. Need be I will post the service for you.
  14. #14
    Join Date
    Sep 2010
    Location
    virginia
    Posts
    5,803
    Did you hook up all the vaccume lines? Sounds like a big vaccume leak if the idle is rough but runs fine
  15. #15
    02 Mazda Protege5
    Join Date
    Jul 2012
    Location
    Pflugerville, TX
    Posts
    7
    Well its a rough start but won't remain on unless I keep it above 2000 rpms. So I re-gapped the spark plugs. here is a video update.
Similar Threads
  1. 626 2.0L (UK 1999 model) - Cranks but NO start
    By colincowan in forum Other Lounge
    Last Post: 01-03-2012, 02:42 PM
  2. Christmas Problems, car cranks but won't fire
    By callITaDAY in forum MSP Problems
    Last Post: 12-26-2011, 01:56 AM
  3. Cast and Forged Cranks
    By thepope540 in forum Protege Performance
    Last Post: 01-14-2010, 10:06 PM
  4. Engine Cranks but Does Not Start
    By highrpm in forum Protege Performance
    Last Post: 05-06-2009, 11:46 PM
  5. 95 1.5L cranks over, but no spark. No power to the coil?
    By Shaftmaster in forum Protege Performance
    Last Post: 04-15-2007, 05:39 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
