Compare auto reliability with reliable results at TrueDelta.com!
Results 1 to 8 of 8
Thread: Rear shock rattling noise
  1. #1
    Registered Member Olde English 5's Avatar
    2009 Mazda5 GT
    Join Date
    Nov 2011
    Location
    Novi MI
    Posts
    42
    So I have a rattling noise coming from the rear shock on the driver's side. When you wiggle the plastic shock boot you can hear what sounds like a thin piece of metal rattling, so I hear this almost all the time on roads that are even a little bit bumpy. The other side doesn't have this noise, you can wiggle the shock boot but no metal rattling. Yesterday I had the back end of the car up on jack stands with the wheel off looking for any loose parts but didn't find any. Also the rattling noise is gone with the car lifted up and the wheel off.
    Anyone else seen this before on your 5? Could it be something loose or broken inside the shock? I could replace the rear shocks if I had to, even though they don't leak and they're the originals with only 53000 miles on them. They are a bit bouncy when I do the "bounce test" on the back bumper but not too bad. I also seem to notice the back end of the car sways side to side a bit going over big bumps at higher speed.
    One more bit of info, the shock with the noise has some vertical scratch marks on it that go right down to the bare metal. The other side looks like it has the same scratches but they're very faint. I have a picture in my phone and I can try to get it posted on here for anyone who wants to see it.
    Any ideas/suggestions are welcome. Thanks!
  2. #2
    "The One And Only" Davicho's Avatar
    Zoom•Zoom
    Join Date
    Oct 2008
    Location
    Claremont, CA
    Posts
    1,428
    Definitely replace your rear shocks. 50K miles is the norm for the rear shocks.
    2012 LIQUID SILVER MAZDA5 GRAND TOURING **SOLD**
    2015 SOUL RED MAZDA CX-5 GRAND TOURING
  3. #3
    Registered Member Wishmaster's Avatar
    07 Galaxy Gray AT Mazda5 GT
    Join Date
    Apr 2007
    Location
    Port Moody / Metro Vancouver / BC / Canada
    Posts
    362
    And as always needs to be said... don't replace with OEM mazda shocks, they'll just blow again very quickly, get something aftermarket. Cheap and reliable are the KYB's or Munroe's. But if you're looking for more performance, tuning, etc... there are lots of options out there... and more expensive.
  4. #4
    Registered Member
    Join Date
    Sep 2008
    Posts
    8
    I replaced my shocks/struts (Sensen struts) but still have that same rattling sound the OP has... and I still can't find it... Everything feels/looks tight when off the ground (looking at suspension bushings, etc).
  5. #5
    Join Date
    Apr 2007
    Location
    Posts
    362
    Have you replaced the sway bar bushings? An easy diy and another very weak point in the Mazda5 Suspension set-up that is often the culprit when people complain of noises from the rear.
  6. #6
    Registered Member
    Mazda 5 Sport 2010
    Join Date
    Nov 2012
    Location
    PA
    Posts
    4
    I just replaced mine 3 days ago at 58K miles. The left one (rear) was leaking bad. Easy job to do and it does help to have an impact wrench, but not necessary if you have strong hands. Cost me $78 at autozone for the pair.
  7. #7
    Lover of 5's Robotaz's Avatar
    2009 Mazda5 GT
    Join Date
    Aug 2009
    Location
    Mexington, KY
    Posts
    1,426
    Quote Originally Posted by Olde English 5 View Post
    Do you have any play between the shock and the "ears" of the mount at the bottom? I've heard of people hearing noise because of the shock shifting back and forth on the bolt.
  8. #8
    2009 Mazda5 GT
    Join Date
    Nov 2011
    Location
    Novi MI
    Posts
    42
    The mounts were nice and tight. All the noises are gone after replacing the shocks. The old ones were toast
Similar Threads
  1. Clunking Noise - Rear Passenger Shock
    By 7rrivera7 in forum Protege Wheels, Tires, Brakes & Suspension
    Last Post: 09-12-2011, 12:30 PM
  2. Rattling noise from rear axle ?
    By urir10 in forum Protege Wheels, Tires, Brakes & Suspension
    Last Post: 04-07-2010, 11:55 AM
  3. rattling noise when fan is on
    By TOMS in forum Mazda5 Lounge
    Last Post: 04-20-2009, 12:10 AM
  4. rattling noise coming from rear right wheel
    By splitvizion in forum Mazda3 Wheels, Tires, Brakes & Suspension
    Last Post: 06-22-2006, 10:49 AM
  5. Popping/Rattling Noise in rear of 3s Hatch
    By taylor5 in forum Mazda3 Lounge
    Last Post: 03-26-2004, 10:04 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
