Shop at EdgeAutosport.com to make your Mazda Go Fast AND Look Good!
Results 1 to 7 of 7
Thread: Engine code. P2096
  1. #1
    Engine code. P2096
    So I'm getting this code. This code only shows up when I go on long trips, 500+ miles. It apparently is in reference to my o2 sensor. I have a Corksport tp and dp. I was thinkin I may need to change my sensor, but the light has now gone off. Should I worry. Any way to monitor to see if this sensor is working properly?
  2. #2
    No insight?
  3. #3
    Registered User speed3 britz's Avatar
    07 Mazdaspeed3, 93 B2600i 4x4
    Join Date
    Aug 2010
    Location
    Detroit / Toledo
    Posts
    683
    Items for Sale
    I had this for awhile, with stock exhaust. I ended up getting new O2 from dealer for about $190 and haven't had it since
    07 Mazdaspeed 3 Grand Touring Black Mica
    HKS Suction Intake - COBB TIP, AP - TurboXS Hybrid BPV - SU TestPipe - CNT Racing CBE - A'PEXi Turbo Timer - NGK LTR7IX-11 - Autotech Internals - CP-E Triple Gauge Pod, RMM, Safe-Seals - SURE Boost Tubes - Prosport Boost, Oil Temp, Oil Press - Corksport Interior LED's - JBR SSP, Heavy Knob, TIGs, EGR Block Off, Shifter Bushings, AP Mount - Hawk HPS Pads with Centric Powerslot Rotors - SenSen Mazda5 Shocks and Struts - H&R Sport Springs - SPC Rear Camber Arms - 18x8+30 350z Touring V1's - 205/40/18 Federal 595EVO - 35% Tint Front, 5% Tint Rear
    91 Mazda Miata MX-5 White
    Racing Beat High-Flow Intake, CBE - Exedy OEM Replacement Clutch - Raceland Coilovers - 16x7+38 ASA AR-1's with 205/45/16 Yokohama's
    93 Mazda B2600i 4x4
  4. #4
    did you run into any driving issues. I haven't at all. Im getting 2096 and 2097 at the same time, so it does point to a messed up o2 sensor. One is for A/f to lean and one is for A/f to rich. The engine light keeps coming on and off. Why idea why it doesn't just stay on?
  5. #5
    Registered User MSMS3's Avatar
    Join Date
    Jul 2008
    Location
    Gulfport, Mississippi
    Posts
    1,860
    Items for Sale
    IIRC, that code is indicative of a failing secondary O2 sensor. May be wrong. Could also mean a crack or leak close to a catalytic converter, if your dp has one. It also shows up with aftermarket dp/s when the secondary bung height is not correct for exhaust flow reading on catless dp's. Just some thoughts.
    Sunlight Silver '08 MS3 GT
    Mods:
    TurboXS DP/RP "Stealthback" package into stock CBE; Vibrant 3 inch Ultra Quiet Resonator in RP section, Magnaflow 3 1/2 unrolled exhaust tip; Mazdaspeed CAI w/air straightener and K&N filter; NGK Iridium IX LTR7IX-11 one step colder plugs; Hypertech tune; Autotech CDFP internals; stock BPV; Yokohama Advan Neova AD08's stock size on stock rims; Grimmspeed EBCS in two port mode; Hawk HPS pads.
  6. #6
    Registered User ScarMS3's Avatar
    2008 MS3 Silvah
    Join Date
    Apr 2010
    Location
    Charleston, SC
    Posts
    91
    Items for Sale
    get something to tune with, such as ap, hypertech or versatuner, you can monitor with ap and versatuner. you could also buy a used dashhawk perhaps to monitor with, but they are getting scarce. also running a downpipe with no tune and no upgraded fuel pump internals could be a recipe for boom.
  7. #7
    Join Date
    Aug 2010
    Location
    Detroit / Toledo
    Posts
    683
    Items for Sale
    Quote Originally Posted by koston33 View Post
    To answer your question, I never had any driving issues... which made me argue with myself about replacing the O2. I had driven a MS6 with a failing O2 and it pretty much shut down the performance, put the car into "Safe Mode." I never noticed anything like that with mine. But finally I committed and just bought one and that was the fix, haven't had a single CEL since. Mine did the same thing before, on and off multiple times and stayed on for multiple lengths. Even with shut-off from a scanner, it would kick back on. I recommend swapping it out. I did notice an increase with MPG too, about 21 before and now I'm getting 26 after changing it.
Similar Threads
  1. Engine threw CEL P2096...
    By Akaveli in forum Mazda3 Engine, Transmission & Drivetrain
    Last Post: 04-01-2011, 01:59 AM
  2. engine code
    By reynoldsrobbie in forum Mazda6 Lounge & Welcome Area
    Last Post: 02-01-2010, 01:06 PM
  3. Engine code help please?
    By MysteriousSkin in forum Mazda Protege 5 (Protege5.com)
    Last Post: 11-26-2009, 02:02 AM
  4. engine code / mazdaspeed3 engine swap?
    By shad0wsfall7 in forum MS3 Engine, Transmission & Drivetrain
    Last Post: 10-22-2007, 06:16 PM
  5. MS6 engine #/code help
    By Klip in forum Mazda6 Engine, Transmission & Drivetrain
    Last Post: 12-08-2006, 02:58 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
