CorkSport.com is MAZDA PERFORMANCE!
Results 1 to 2 of 2
Thread: Changing transfer case oil - 2001 Tribute
  1. #1
    Registered Member
    2001 Mazda Tribute 5-sp 4WD
    Join Date
    May 2012
    Location
    DC metro area
    Posts
    2
    Can anyone tell me how you change the gear oil in the transfer case on a 2001 Tribute? The Haynes manual says there's a drain plug, but I think they are using pix from the V-6 engine. Attached please find 2 pix that I took of my transfer case tonight, one from the front and one from the rear. I don't see a drain plug; that thing that looks like a drain plug in one phote is cast into the housing. 1338250450670.jpg1338250505198.jpg
    I did find this online at http://www.ehow.com/how_8617247_chec...rd-escape.html
    "Ford Motor Company uses what they call a sealed transfer case assembly in its 2001 Escape models even though there is a drain plug to drain and refill the unit. Routine maintenance has been eliminated through the use of synthetic lubricants. Unless the transfer case leaks or has been repaired, Ford considers the unit lubricated for life. Leaks show up as dark or dirty spots on the transfer case and indicate the need for periodic fluid checks and repairs."
    I can live with this if this is how Ford/Mazda intended it; I just want to put something like Lucas or another additive in there to smooth things out a little more. I just don't want to pay $250 to have a dealership tell me this when there are plenty of smart guys in the community. Thanks.
  2. #2
    Registered Member
    Join Date
    May 2012
    Location
    DC metro area
    Posts
    2
    O.k., I should have said, "Do I need to really worry about changing the oil in the transfer case?" Because from both how it's built (no drain plug--at least that I can see), and the info above, it appears that Mazda & Ford don't want anyone to worry about it. Correct?
Similar Threads
  1. Transfer case Leaking
    By MAZDASP6 in forum MS6 Lounge
    Last Post: 02-16-2012, 08:16 AM
  2. Wtb transfer case
    By Win in forum Completed Transactions
    Last Post: 01-04-2012, 09:56 PM
  3. WTB: '06 MS6 Transfer Case
    By bobby0283 in forum Completed Transactions
    Last Post: 05-29-2009, 10:26 AM
  4. MS6 Transfer case leaking
    By InlineTwin in forum Mazda6 Engine & Transmission
    Last Post: 11-27-2008, 11:23 AM
  5. Bad Transfer Case
    By bzebra in forum CX-9 Engine & Transmission
    Last Post: 03-27-2008, 12:04 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
