Upgrade your Mazda with High Quality Parts at Great Prices from James Barone Racing!
Results 1 to 7 of 7
Thread: Request: AWR (or other) dogbone mount
  1. #1
    Registered Member
    2012 Mazda 2 Touring SG 5MT
    Join Date
    Apr 2012
    Location
    Gainesville, GA
    Posts
    1,407
    I noticed a few of you have done this and am curious on how the install went and how significantly NVH has increased with the 70 durometer urethane.
  2. #2
    I dropped a deuce...... CRG Racer24's Avatar
    '11 Mazda2 GX-Convenience Pkg.. Warranty Voiding Mods
    Join Date
    Mar 2012
    Location
    Mississauga, Ont.
    Posts
    822
    If you have access to a shop, it literally takes 10 mins. If not, you jack the car up, put it on stands on the front end, then put your floor jack under the oil pan/engine just so it makes contact, not that it's pushing on it preferably with something on the jack to distribute load on your engine/oil pan. Unbolt the stock mount, pop in the new mount making sure the 2 bolts are lined up. Tighten them up good and tight and you're golden. I'm assuming that's what you would do since I did mine at the shop.
    If anyone knows if they're any torque specs on the bolts, please chime in.
    But I have the 95a mount, and I'm used to HEAVILY modded and VERY noisey/stiff/harsh cars. There is a lot of vibration with that mount, but I'm completely fine with it. Not many people would be okay with the amount of NVH the 95a one has, but I'm hardcore when it comes to cars anyway.
    -Alex
    '11 Mazda 2 GX w/ Convenience pkg Liquid Silver. Totalled
    Mazda 2
  3. #3
    Registered Member
    Join Date
    Apr 2012
    Location
    Gainesville, GA
    Posts
    1,407
    Thanks!
  4. #4
    Authentic Redneck ngd298's Avatar
    '87 RX7 Sport, '13 Frontier Pro-4x 6MT, '98 Metro, '08 Ninja
    Join Date
    Oct 2011
    Location
    Bristol, VA
    Posts
    495
    Try filling the hollow parts of your lower mount with 3M window weld. Great results and very little vibration. Not sure how it compares to the AWR mount but it's much better than stock.
    Current Mods- Sparco 16x7 Wheels, Eibach Springs, CS SRI & Duct, RB Exhaust, Rear Torsion Bar, Custom Rear Motor Mount, ~40% Tint, Armrest, CS Short Shifter, Hawk HPS Brakes
    Future Mods- Deer imprint removal
    Other deer imprint removal
  5. #5
    Registered Member
    Join Date
    Apr 2012
    Location
    Gainesville, GA
    Posts
    1,407
    Yea, I just might try that. I saw the write-up on here about it. I've got a well modded forester that has a tranny mount filled with that stuff (didn't fill it myself though), its super solid. Do most hardware stores carry it?
  6. #6
    Join Date
    Oct 2011
    Location
    Bristol, VA
    Posts
    495
    I'm not sure, I got mine at Advance Auto Parts. It was around $20, which is kinda high but it beats having to buy a new mount.
  7. #7
    Registered Member
    Join Date
    Apr 2012
    Location
    Gainesville, GA
    Posts
    1,407
    So after more than 2 years I finally got around to doing this. The bolt sleeve on the tranny side of the mount was too long on the awr mount I received, and no amount of wacking with the deadbolt mallet would pursuade it go in (instead it just dug into the mount housing on the tranny). I used a file to remove some material from the bolt sleeve (a socket and mallet work good for removing the sleeve) as well as chamfer the edges. I then went in without too much trouble. I will also say it is difficult to pull the motor up into position and slide the bolt in on the subframe side without a helper. I did it, but having an extra hand would've made that part a peice of cake.
Similar Threads
  1. FS: TRZ Dogbone Mount (60 duro)
    By jsief85 in forum Completed Transactions
    Last Post: 01-13-2011, 11:55 PM
  2. FS: TRZ Dogbone Motor Mount & Transmission Mount
    By fostersafb in forum Completed Transactions
    Last Post: 03-18-2009, 11:18 AM
  3. TRZ(dogbone) vs. SU motor mount!
    By djza2u1 in forum MS3 Engine & Transmission
    Last Post: 03-01-2009, 09:59 PM
  4. Help! TRZ Dogbone or CPE Motor mount?
    By Abilor in forum MS3 Engine & Transmission
    Last Post: 01-05-2009, 04:44 PM
  5. Anyone considering the TRZ Dogbone Motor Mount.......
    By nytmar3 in forum MS3 Engine & Transmission
    Last Post: 04-22-2008, 02:43 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
