In Memory of Mazdas247 Member "1338"
Results 1 to 12 of 12
Thread: Whichl manual transmission fluid is best to use?
  1. #1
    Registered Member speed3_07's Avatar
    2007 mazdaspeed 3
    Join Date
    Feb 2011
    Location
    burbank
    Posts
    2
    my MS3 is almost at 45000 and its about time to change the trans fluid.
    i have been looking around the forum but have not found any for sure answers. not sure to use mazda oem fluild or what?
    Need help please
  2. #2
    Scrooge McDuck WillD's Avatar
    MS3, Miata & PVB Moderator
    Classic Red 1991 Miata, Magnetic Gray Metallic 2014 Tacoma
    Join Date
    Aug 2010
    Location
    Amherst (Cleveland), Ohio
    Posts
    6,368
    I'm not normally one to do this, but literally two threads down the page is this: http://www.mazdas247.com/forum/showt...ge-trans-fluid
    In which several people, including me, recommend the Motorcraft Fully Synthetic MT Fluid from Ford.
  3. #3
    2007 mazdaspeed 3
    Join Date
    Feb 2011
    Location
    burbank
    Posts
    2
    ya just wanted to see if there were any other recommended fluids
    and thanks for replying back
  4. #4
    Registered Member Russm's Avatar
    08 MS3
    Join Date
    Mar 2008
    Location
    Kenosha, WI
    Posts
    413
    Use Motorcraft in 08 MS3 with 81K on odometer and this is first winter in Wisconsin that I haven't had the noise and super hard shift into 2nd normally expweianced in WI winters..
  5. #5
    King Kokanee skallen's Avatar
    2007 Mazdaspeed 3
    Join Date
    Jun 2009
    Location
    Kelowna, BC, Canada
    Posts
    465
    I got brutal 1st to 2nd gear hard shift. You can literally hear the grind every morning. Haven't changed the fluid yet, but I will. Canadian winters suck! My car has 58,000KM....so it's time to change the gear fluid.
    Cobb SRI, TRZ Rear Mount, Progress RSB
  6. #6
    Registered Member Wurf's Avatar
    2010 CX9 Blue
    Join Date
    Feb 2009
    Location
    Michigan
    Posts
    747
    Motorcraft Synthetic Manual Trans results feedback:
    Picked up my car yesterday after having the Motorcraft XT-M5-QS Synthetic put in it.
    Right out the parking lot I put it in first and drove around slowly with the radio off.
    I made some turns from lock to lock, on and off throttle listening for noise.
    The gear noise from the diff seemed more quiet and shifting is about the same but slightly smoother and easier.
    All I have is a SURE RMM no other bushing upgrades or mods.
    First cold drive this morning. Shifting into second was my only minor gripe previously. It would almost always grind just a little bit when cold.
    Now it's better, but not a lot different when stone cold. Happened to me right after leaving my driveway and then never again on the way to work.
    It improved almost immediately once there was some heat in the motor so I'd say it was worth the $70 ( plus tax ) for the Motorcraft stuff.
    Actually what's more remarkable is the smoother idle after the oil change! I was running Castrol GTX synthetic and only had 3700 miles on it. I put Mobil1 Super Synthetic in it this time as it was less expensive by about $4 for the 5qt jug at Walmart. Idling at lights is surprisingly smoother now. I've never noticed that before.
  7. #7
    2010 CX9 Blue
    Join Date
    Feb 2009
    Location
    Michigan
    Posts
    747
    Further feedback.
    Reverse is MUCH quieter. Like amazingly less noise from the diff.
    Second gear is now about the same as it was before. If I don't want grind when cold, I need to double clutch for the first few miles.
    It's better in less time than before however.
  8. #8
    Registered Member meicalnissyen's Avatar
    07 BM GT
    Join Date
    Jan 2009
    Location
    TAMPA FL
    Posts
    1,837
    Im having a Yogi Berra moment
    Cuz its like Dejevu , all over again
    A democracy, in its purest form, is well represented by a group consisting of 2 wolves and 1 rabbit. Voting on what to have for lunch
  9. #9
    Registered Member ericrapp's Avatar
    mazdaspeed 3 cosmic boo
    Join Date
    Dec 2007
    Location
    Fairport ny at the Erie canal
    Posts
    3,647
    Cool
    i use redline mt 90 but i only drive warm weather. the motorcraft is assumed the best product. i have changed my fluid once from stock and twice more just to see. and i am clean as a whistle when last changed at about 68k when i replaced axle shaft
  10. #10
    Registered Member
    Mazda, MS3
    Join Date
    Nov 2007
    Location
    Sask, Can
    Posts
    113
    Finally bought some Motorcraft. Holy crap is it expensive!
    Will change it this weekend at 45k
  11. #11
    BigDaddyMS3
    Mazda, Speed3
    Join Date
    Dec 2009
    Location
    Dublin
    Posts
    148
    Smile
    My local Ford dealer has it for $22 @ quart. The odometer just hit 40K after five years so I'll start saving money now for the next five year interval.
    The James Barone Racing short shift kit plate and Sure RMM really made the 1-2 shift like budda' especially above 60' fahrenheit or when warmed up.
  12. #12
    Join Date
    Dec 2007
    Location
    Posts
    3,647
    Happiness is a good 2-3 shift!!
Similar Threads
  1. Manual Transmission Fluid
    By CheeseHelmet in forum Protege5 Lounge
    Last Post: 08-12-2014, 04:15 AM
  2. Replies: 2
    Last Post: 10-10-2011, 11:15 PM
  3. manual transmission fluid
    By cramit in forum Protege Performance
    Last Post: 07-17-2010, 02:43 PM
  4. Transmission fluid (on a manual)
    By JT87 in forum Protege5 Lounge
    Last Post: 11-05-2006, 02:53 PM
  5. Manual Transmission Fluid
    By cop1976 in forum Protege5 Lounge
    Last Post: 08-28-2006, 03:43 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
