Compare auto reliability with reliable results at TrueDelta.com!
Results 1 to 8 of 8
Thread: No Spark, Wont Start
  1. #1
    Registered Member
    Join Date
    Jun 2008
    Posts
    2
    If anybody could give me some advice, my car cranks but has no spark. I was told to change crankshaft posn sensor and I did, but no luck. Cleaned mass air. I'm no mechanic and dont even now where to begin.
  2. #2
    Registered Member
    2002 Protege5, Classic Red
    Join Date
    Dec 2011
    Location
    Raleigh, NC
    Posts
    120
    no spark on all cylinders? Or did you just check one?
    Someone else chime in though, but sounds like a coil packs or something else related to the ignition system
    I should add: Did you physically take the spark plug boots off a plug and take one of the plugs out and turn the engine over to see if there was spark
    or did you get the car checked by a dealer?
  3. #3
    Registered Member
    Join Date
    Jun 2008
    Posts
    2
    I took out the two spark plugs not attached to the coils and put the boots back on, I then I cranked with no spark out of either plug. When I turned the car off there was one spark, only on one plug.
  4. #4
    Registered Member
    Join Date
    Dec 2011
    Location
    Raleigh, NC
    Posts
    120
    uhh, I've officially gone out of this discussion. Are you saying when your key turns off there is a spark? it should definitely NOT be doing that. I've never heard of any car doing that.
  5. #5
    Registered Member tweety2300's Avatar
    2001 mazda protege mp3
    Join Date
    Sep 2010
    Location
    virginia
    Posts
    5,806
    +1 if it did that then the car is possesed and needs a trip to the crusher. now if your saying that one of the plugs sparked then its probly coil packs. do you have any cels?
  6. #6
    Registered Member TURBOJ1's Avatar
    Protege,ES T
    Join Date
    Sep 2010
    Location
    N Y C
    Posts
    553
    GET SOME STARTER FLUID and spray into the intake
  7. #7
    Join Date
    Sep 2010
    Location
    virginia
    Posts
    5,806
    How is that gona helpif he's not geting spark?
  8. #8
    Banned
    Donated: $13.37
    Banned For Being A Troll
    Join Date
    Sep 2011
    Location
    Canada
    Posts
    2,305
    Quote Originally Posted by TURBOJ1 View Post
    So you are hoping that this will turn out to be magic spark juice?
    If there is no spark, it could be Ignition or EMS related.
    Ignition could be Coils, Grounding, Fuse, Power, Relay
    EMS could be, Cam Sensor, Crank Sensor, or Faulty wire to the ECU.
Similar Threads
  1. Car wont start
    By Wackys13 in forum MSP Problems
    Last Post: 10-24-2011, 04:46 PM
  2. Car electrical wont come on wont start
    By Soulend in forum Protege Lounge
    Last Post: 11-09-2010, 11:11 PM
  3. 1998 626 2.5 has spark and fuel presure wont start
    By plowboy in forum Other Lounge
    Last Post: 04-03-2010, 06:37 PM
  4. its -25 my car wont start and my hood wont pop!
    By CE02P5 in forum Protege5 Lounge
    Last Post: 01-15-2009, 02:52 PM
  5. Help Pro 5 wont start
    By 2003pro5 in forum Global
    Last Post: 12-25-2006, 11:02 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
