In Memory of Mazdas247 Member "1338"
Results 1 to 5 of 5
Thread: Grinding noise when steering to the right
  1. #1
    Registered Member
    Join Date
    Apr 2008
    Posts
    41
    We started getting vibration and grinding noise when turning to the right. I assumed it was the rotors. Put on new rotors and pads. Didn't fix the issue. The sound is coming from the front driver's side. Any ideas?
    Thx,
    -PJ
    2008 Mazda CX-9 GT w/ GT assist pkg and DVD
    2007 Toyota 4Runner SE 4WD V8
  2. #2
    Registered Member
    Join Date
    Apr 2008
    Posts
    41
    Our Mazda service guy suspects it's a wheel bearing issue. I'll know on Monday if that's the issue.
  3. #3
    Registered Member ceric's Avatar
    2016 Mazda6 iGT, 2014 Mazda3 sGT hatchback
    Join Date
    Jan 2008
    Location
    Northern California
    Posts
    3,828
    Likely it is the bearing. Rotor and pad usually does not make noises when you turn it left/right.
    Bearing, however, is stressed side-way when doing that.
    2016 Mazda6 iGT + Tech Pkg
    ....Sonic Silver Mica / Parchment
    ....Soul Red Metallic / Almond
  4. #4
    Registered Member
    Join Date
    Apr 2008
    Posts
    41
    Yep, it was the bearing. Another CX-9 was also getting a bearing replaced.
  5. #5
    Registered Member
    2009 Mazda 5
    Join Date
    Mar 2012
    Location
    IL
    Posts
    1
    I am having an issue with grinding during left turns. Just curious, how many miles were on your bearings? Im at 55K.
Similar Threads
  1. Steering Wheel Grinding?
    By Silver Ecstasy in forum CX-7 Lounge
    Last Post: 06-14-2011, 02:55 PM
  2. Grinding/screeching noise when turning the steering wheel
    By dandydaniel in forum MS3 Engine & Transmission
    Last Post: 02-16-2011, 01:42 PM
  3. Grinding Noise
    By GhostMercury in forum MSP Problems
    Last Post: 04-21-2007, 02:45 AM
  4. Grinding from Steering Column
    By Skywlkr in forum Mazda6 Lounge
    Last Post: 03-12-2007, 10:24 AM
  5. Tranny Noise? LSD Noise? Something grinding/scraping!
    By daschissnit in forum Protege5 Lounge
    Last Post: 08-09-2005, 07:45 AM
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
