Compare auto reliability with reliable results at TrueDelta.com!
Results 1 to 4 of 4
Thread: 2009 Mazda5 Radio Wiring Harness
  1. #1
    Registered Member tefloncandi's Avatar
    2009 Mazda5
    Join Date
    Jul 2010
    Location
    Waco,Texas
    Posts
    98
    Does anyone know what the wiring color code for the radio harness, in particular i am looking for the light wiring because I removed my Pioneer radio which was installed professionally and they told me that I will not be able to dim or brighten the lights on my unit. As I posted before it is too bright. Today I removed my unit and found out that light wire is not even hooked up so I do not know how the unit is getting power to light it up?????
    The unit is a Pioneer AVH-P4300DVD
    Any suggestions??
    Neil"Tefloncandi"Mala
    [SIGPIC]
  2. #2
    Registered Member dieseldriver's Avatar
    Join Date
    Oct 2011
    Location
    Bergen County, NJ
    Posts
    442
    You may just be able to tap into the rear wire pair of the dimmer that's on the dash. It's just a potentiometer that varies the input voltage. Just use a vampire tap to tap into the positive wire.
    Quote Originally Posted by tefloncandi View Post
    Any suggestions??
    Currently own:
    2012 Mazda5 GT -- Clear Water Blue Mica
    2012 Speed3 Touring with Tech Pkg. -- Crystal White Pearl Mica
  3. #3
    Registered Member SonicBoy's Avatar
    2012 Mazda3 GTE - Indigo Lights Mica
    Join Date
    Jan 2008
    Location
    Toronto, ON Canada
    Posts
    167
    The unit probably just uses full power if the light dim lead is not connected. This is the default for most systems as installation into older cars withouth the dim lead would mean no lights.
  4. #4
Similar Threads
  1. AWR Rear MM, Aftermarket Radio Wiring Harness And Single DIN Pocket
    By CheeseHelmet in forum Completed Transactions
    Last Post: 09-02-2010, 08:44 PM
  2. Mazda5 wiring harness
    By Trdkamuri51o in forum Mazda5 Engine & Transmission
    Last Post: 09-07-2009, 01:03 AM
  3. Wiring Harness Pinout for Radio connector
    By Billy_JR in forum Mazda5 Audio
    Last Post: 11-30-2008, 10:14 AM
  4. WTB: Stock P5 Radio Wiring Harness
    By Onatrum in forum Completed Transactions
    Last Post: 01-03-2007, 12:13 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
