CorkSport.com is MAZDA PERFORMANCE!
View Poll Results: How helpful was this post?
Voters
4. You may not vote on this poll
  • Helpful and explained very well
    3 75.00%
  • Helpful, but could be explained better
    1 25.00%
  • Explained well, but not helpful
    0 0%
  • Hard to understand and not helpful
    0 0%
Results 1 to 3 of 3
Thread: Replace A Mazda 5 Headlamp Bulb - Low Beam
  1. #1
    Registered User
    Mazda 5, Mazda Tribute, & 1996 Miata MX-5
    Join Date
    Dec 2011
    Location
    Hopewell, NJ
    Posts
    4
    Items for Sale
    Mazda 5 Headlight Bulb Replacement (Low Beam)
    A. This is a frustrating job for most people because the opening in the back of the headlamp is too small for even small fingers, and it takes considerable force to release and re-tension the metal clip that holds the bulb in place. I've found a trick that makes this job a bit easier (it's still a challenge) and am sharing it in this post. The bulb is held in with a metal clip that is nearly impossible to re-clip by your bare hands. Therefore, fashion a tool to assist with the job from an 8” long flat spade screwdriver. Notch the screwdriver in the center of the blade so that the position of the end of the bulb retaining clip can be captured and manipulated into position. Photos are shown below of a screw driver modified with a notch, and a H7 replacement bulb:
    B. To remove the old bulb, do the following steps:
    1. Make space to work by removing any plastic covers in the vicinity of the back of the headlamp.
    2. Unplug the electrical socket from the back of the headlamp.
    3. Gently pry off the rubber boot on the back of the lamp that prevents water infiltration.
    4. Inspect how the bulb is held in place with the retaining clip so that you will know what it looks like when it is properly holding the bulb in position. Use the notched screwdriver to carefully release the bulb retaining clip, and swing it out so that the old bulb can be removed. The clip is too big for the opening in the back of the lamp to swing out without some twisting and manipulation of the end of the clip. With some effort it can be twisted clear of the opening. The photo shows the screw driver blade just prior to pushing and releasing the end of the retaining clip:
    5. Disconnect the bulb from the front of the H7 socket adapter and discard the old bulb.
    C. To install the new replacement bulb do the following steps:
    1. Wear surgical gloves for the following steps so that you don’t get natural oils from your hands all over the new bulb and reduce it’s life span.
    2. Attach the new H7 bulb into the H7 socket adapter and position this assembly into the back of the headlamp so that it fits. There is a stub on one side of the bulb socket that only allows the assembly to fit in snuggly one way.
    3. Swing the bulb retaining clip so that it begins to hold the bulb assembly in place. The clip is too big for the opening in the back of the lamp, so it will take some twisting and manipulation to get the clip inside the opening.
    4. With the bulb in position, and the clip inside the opening, use the notched screwdriver to push and hook the end of the clip into it’s final position. It takes considerable effort to push the clip in place.
    5. Apply some bulb grease around the inside flange of the rubber boot that keeps moisture out of the headlamp. Press the rubber boot onto the headlamp and back of the bulb socket.
    6. Press the socket back onto the connections for the bulb.
    7. Replace all the various plastic covers to complete the job!
  2. #2
    Registered User
    Mazda 5
    Join Date
    Jan 2012
    Location
    Kamloops
    Posts
    1
    Items for Sale
    Great info and pics, but I was confused when I looked at the replacement bulb and finally realized that the silver
    piece needed to be separated from the black plastic piece (socket adapter). I did this with a large flat bladed screwdriver. Up until I did this, I thought I had the wrong bulb.
  3. #3
    Registered User
    Join Date
    Dec 2011
    Location
    Hopewell, NJ
    Posts
    4
    Items for Sale
    How the Bulb looks with and without the H7 Socket Adapter
    I realized after the job was done that I should have taken a picture of the new bulb next to the old bulb connected to the H7 socket adapter. It would have made it easier for others to see what to expect. But I wasn't about to undo the job after it was done. You are right that they look quite different when connected, and one might make the mistake of thinking that they had the wrong bulb. Your comment should help clarify it for others. Glad you figured that step (Section B, Step 5) out for yourself!
Similar Threads
  1. Low beam headlamp aim?
    By ckfreeman20 in forum Mazda3 Accessories & Appearance
    Last Post: 04-10-2011, 09:42 PM
  2. Replace High beam headlight bulb
    By polypep in forum Mazda6 & MAZDASPEED6 Car Audio & Electronics
    Last Post: 10-26-2009, 09:03 AM
  3. Replacing low beam bulb on '04 Mazda 3
    By mrschmitt33 in forum Mazda3 & MAZDASPEED3 How-To
    Last Post: 08-24-2007, 12:23 AM
  4. Help changing headlamp bulb (Bulb seating wire!!?!?)
    By Mark115 in forum Mazda Protege 5 (Protege5.com)
    Last Post: 03-13-2007, 11:37 PM
  5. For Mazda 3: How to replace the HID Bulb by myself?
    By yyz in forum Mazda3 & MAZDASPEED3 Car Audio & Electronics
    Last Post: 10-03-2006, 07:26 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
