Upgrade your Mazda with High Quality Parts at Great Prices from James Barone Racing!
Results 1 to 12 of 12
Thread: check engine light blinking not solid no more
  1. #1
    Registered Member
    01' mp3
    Join Date
    Jun 2010
    Location
    Stockton, C.A.
    Posts
    19
    Red face check engine light blinking not solid no more
    i have a problem with my 01' mp3 and need help desperatly. heres what happend 1st i had the CEL light on solid and had my friend check it for me with his code reader and showed us the bottom o2 sensor is bad. i did remember replacing the top one a month before but forgot to change the bottom one till this day. so i drove back home on the freeway, then my car started to act up and kind of sputtering(speed kinda drop down and wont accelerate). so i pulled up at the next exit and parked at the autozone. smoke came out and it smelled bad. checked under the car and u can see clearly that the bottom o2 sensors went completly out because the smoke came out from it. i pulled it out and it was dark and no good. got me a new cheap one that i have to splice a rig to make the plug fit. finally install it in then i start up my car..... the CEL was blinking but i didnt thaught iti was a big of a deal so i drove home a couple miles later the car started to act up again but no smell and wasnt that bad of a sputter... please someone help me with this problem im super new to this........
  2. #2
    Registered Member
    01' mp3
    Join Date
    Jun 2010
    Location
    Stockton, C.A.
    Posts
    19
    ok i had my friend diagnose my CEL with his code reader and it show multiples misfire code p0300. his opinion was that it might be the coils and/or spark plugs went out. then we try to pull the plugs out while car is running and everything seems to be fine(car shakes and act up) meaning its still good.so we googled the code and some dude was having the same problem and had his car serviced at the mazda dealer. they had replace his coils, spark plugs n wires, egr, emission parts etcs etcs. same problem and code occured so then they finally replaced the CAT and no code this time. some other code showed up. i guess he had one problem fixed and another one pops up...... so frustrated can someone give me some help or there opinion on whats the for sure thing to fix. thank you
  3. #3
    Registered Member tweety2300's Avatar
    2001 mazda protege mp3
    Join Date
    Sep 2010
    Location
    virginia
    Posts
    5,803
    your friend is an idiot who pulls out a spark plug while the car is running? replace your coil packs thats causing the miss fire. and since it wasnt a big deal to drive your car while the check engine light was flashing i can bet money you ruined your precat which is the rotten egg smell you were probly smelling. but being in california the only pre cat you can get is from mazda which runs $1,000
    what color was the smoke?
  4. #4
    Registered Member
    01' mp3
    Join Date
    Jun 2010
    Location
    Stockton, C.A.
    Posts
    19
    it was white smoke and godddddaaaaaaam 1k for a pre-cat fuuuuuuuuuck so theres nowhere else i can get a pre-cat here in california?????????
  5. #5
    Registered Member
    01' mp3
    Join Date
    Jun 2010
    Location
    Stockton, C.A.
    Posts
    19
    if to say i bought the coils n it fix my missfire would the car still hesitate becuase of the bad pre-cat??? i know its gonna throw another code if i did fix the missfire..... help me out with some more guys..........
  6. #6
    Join Date
    Sep 2010
    Location
    virginia
    Posts
    5,803
    If you had white smoke its a possibility your headgasket is gone as well an o2 sensor will not make the car smoke.the pre cat being bad won't cause hesitation. What you could do is do the non fouler trick which is illegal but it won't throw a code and the main cat works well enough to pass a sniffer.mazda is the only place you can get a precat to be legal in ca
  7. #7
    MP3 Baby!!!! Protege_MP3_506's Avatar
    2001 Mazda Protege MP3
    Join Date
    Mar 2008
    Location
    roy utah
    Posts
    438
    I had a random multiple cylinder misfire at one time so I replaced my coils plugs and wires and it fixed that problem. If you drove with a misfire for awhile its gonna send a lot of unburnt fuel through and that will clog up your cat as it did mine. I did the non fouler trick and havent had a code for the cat since. That was about 3 years ago. Give it a shot and see what happens. Only takes a few minutes and will run you less than 10 bucks
  8. #8
    Registered Member
    01' mp3
    Join Date
    Jun 2010
    Location
    Stockton, C.A.
    Posts
    19
    newbooty question: whats a "NON FOULER TRICK" please explain to my dumdass in better details thanks you
  9. #9
    Join Date
    Sep 2010
    Location
    virginia
    Posts
    5,803
    Search for it on the forum there's a thread labled "how to non fouler" or somewhere in there or look in the how to section
  10. #10
    Registered Member
    01' mp3
    Join Date
    Jun 2010
    Location
    Stockton, C.A.
    Posts
    19
    YES!!!!!!!!!!! i think i fixed it, but had a vacuum leak which threw a p0106 found and fixed it(one of the vacuum house from the egr boost sensor on the top passenger side next to strut bar) thanks to my fellow mp3 members who helped me. if any more problems in the future ill definetly come back here. you guys are better help than any of my friends. again THANK YOU SO MUCH!!!!!!!!!!!!!! NO MORE CEL
  11. #11
    Registered Member
    Join Date
    Jan 2013
    Location
    Battle Creek
    Posts
    1
    Quote Originally Posted by tweety2300 View Post
    I am sure what he means is he removed the spark plug wire from the spark plug end while the car was running. If there is no difference in how the engine runs when you do this it tells you that its not firing anyway.
  12. #12
    Join Date
    Sep 2010
    Location
    virginia
    Posts
    5,803
    Quote Originally Posted by shifty83 View Post
    You realize there is voltage going through the spark plug wires and without thick enough gloves it will shock the shit out of you right? So basicly still not smart
Similar Threads
  1. Check engine light blinking problem
    By Mixerdriver in forum Protege5 Lounge
    Last Post: 05-07-2010, 07:27 AM
  2. check engine light blinking/ rough idle
    By msp03rbuld in forum MSP Problems
    Last Post: 11-10-2009, 03:43 PM
  3. Blinking Check Engine Light under ACC
    By pchen in forum MS3 Lounge
    Last Post: 03-31-2009, 03:53 PM
  4. Blinking check engine light and limp mode?
    By Jboost in forum MSP Problems
    Last Post: 01-06-2009, 06:41 PM
  5. Check Engine light Blinking
    By chdesign in forum Protege Performance
    Last Post: 07-04-2002, 01:18 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
