Upgrade your Mazda with High Quality Parts at Great Prices from James Barone Racing!
Page 1 of 2 12 LastLast
Results 1 to 15 of 22
Thread: Why would my car just randomly shut off?
  1. #1
    Ky Mazda Chic tiff6's Avatar
    2004 Mazda6 i
    Join Date
    Jun 2009
    Location
    Bardstown, KY
    Posts
    1,657
    Exclamation Why would my car just randomly shut off?
    Recently, sometimes while I'm driving down the road the engine just shuts itself off. There is no warning, no sputter, no over-heating. I'll Just be driving, like normal not zoom zoom, and suddenly I feel I have no power steering and notice my car is not running. Turn the key and it starts right back up. The temp guage reads normal, so I assume this can not be related to the cooling system. It's not setting off any CEL codes.
    First time it happened was about 6 weeks ago, 2nd time was about 2 weeks ago, and in the past few days it seems to be becoming more frequent. 3rd time it occurred was this past Thursday, then it happened twice today. I have asked a few of my mechanic friends about it, one of them thinks it could be related to the crank sensor , even though there is no CEL code to give us any clue.
    He looked at the crank sensor and said it was not excessively dirty, as he suspected, but he did notice the adjustment is turned all the way in one direction. He is an import mechanic, and said that is not normal, from his experience.
    A new crank sensor is cheap and it wouldn't be difficult to replace, but we are not certain this would fix whatever is causing my car to just randomly shut off.
    Does anybody have any clue what could be the issue here? Please.
    2004 Mazda6i (My daily)
    2010 Mazda3s 5-Door Sport (His daily)
    1984 Olds Delta 88 (Our project)
    1969 Chevy Pick-up (Classic Show Truck)
    My Mods: Custom dual-friction clutch; K&N High Flow Air Intake; Custom-made aluminum pedals by ultimatepedals.com; Magnaflow custom 2.5in stainless exhaust
  2. #2
    winta mode bazooka joe's Avatar
    Donated: $40
    2004 MSM, 2014 CX5 Touring, Honda 1976 XL 175
    Join Date
    Oct 2002
    Location
    wbee ma to NC 2016 Jinba ittai
    Posts
    20,193
    do you get any lights flashing, dash lights blinking just before the loss of power?
  3. #3
    Last of The Mo'Ricans Shiftee's Avatar
    10 MS3 SRI/TIP, Forge BPV, SURE CT's, RMM
    Join Date
    Jul 2011
    Location
    St. Matthews
    Posts
    119
    This actually happened to me when I had my accord years ago, turned out to be my ignition switch contacts were just worn down, at 200k plus miles I wouldn't be surprised if this was a possible culprit.
  4. #4
    2004 Mazda6 i
    Join Date
    Jun 2009
    Location
    Bardstown, KY
    Posts
    1,657
    Quote Originally Posted by bazooka joe View Post
    Honestly I'm not certain, but the first time it happened the oil light flashed and the battery light came on. I started to worry that perhaps the oil pump may be going bad.
    At the time I was due for an oil change and had an appointment for the dealer to do it the next day. I didn't mention it to the folks at the dealer when I took it in because I had already taken it to Dr Zoom, immediately when it happened that same day. They looked at it and tried to scan for CEL codes, but nothing showed up other than the usual lean idle because of my intake. One of my friend's at Dr Zoom said well considering the mileage, maybe it was just a random computer fluke. Nothing to worry about.
  5. #5
    2004 Mazda6 i
    Join Date
    Jun 2009
    Location
    Bardstown, KY
    Posts
    1,657
    Quote Originally Posted by Shiftee View Post
    That is probably a good place to check next. Thank you Rey
    Yes I agree. LOL I understand and accept that with as many miles as my car has, there are probably going to be many parts that need to be replaced. Like so many other things, use and time takes it's toll and things wear out. Kind of like how age affects the human body, I think might be a suitable comparison. Not that any of the parts may be defective, but just old. LOL
  6. #6
    U8RICE MSP-2003.5's Avatar
    2003.5 MSP
    Join Date
    Apr 2010
    Location
    Louisville
    Posts
    1,461
    I think the dash lights coming on is bc your engine is off w/the keys in the on position. I assume that you are in neutral when this happens. Do you know if it happens when you have a sudden rpm drop (such as accelerating and then suddenly having to brake and putting car in neutral). If so could be a vacuum leak.
  7. #7
    Mazda Poor!
    Join Date
    Nov 2007
    Location
    Burgin, KY
    Posts
    523
    We've had something similar happen with the Roush. If we have the cruise control on, and we've tripped it out for traffic and such, I have to be careful when I engage it back into service to be sure to have the speed back near where it was set for. If it's a few miles below that, the engine will hiccup and shut down. I can restart it, on the fly, and have all well, again. I took it to the dealer, with codes in hand, and couldn't resolve the problem. Now, I make sure the car is up to the cruise speed before I engage it. I'd say it's a computer fluke, as well. It's hard to fix what isn't broken; so, I can't complain about the dealer. The mechanic did try to get it to fail and couldn't.
    Good luck with your search. It almost has to quit and no restarted before the problem can be found. In our case, after a few restarts, the codes cleared themselves.
    '90 LS6 Miata
    '94 B4000 PU
    '95 Miata
    '06 RX-8 GT
    '08 Roush Mustang
  8. #8
    Donated: $40
    Join Date
    Oct 2002
    Location
    Posts
    20,193
    first thing and an easy thing to check out is your ground wire and battery connections...i wouldn't think you have much corrosion in ky, but it's an easy thing to check first
  9. #9
    2004 Mazda6 i
    Join Date
    Jun 2009
    Location
    Bardstown, KY
    Posts
    1,657
    Quote Originally Posted by MSP-2003.5 View Post
    I have noticed I am actually decelerating when it happens and the car is in gear. I agree with you regarding the dash lights, but it seems all of the lights would be on if that was the case. And the first time it occurred the oil light was flashing, not just on. I'm not sure, but I am thinking it could be a computer related issue.
    Last night, after I posted this thread, Jeff S. (import mechanic) called me with some information. He had been researching my car and this issue online and he found an article or some information that said many Mazda vehicles had experienced the same issue. In 2008 Mazda provided an ECU update for the affected vehicles and this is supposed to resolve the problem. So I was going to call the dealer this morning to ask them about it. I remember they had updated the ECU on my car a few years ago, but I'm not sure when this was. It may be listed on one of my service receipts in the file I keep for my car, but I didn't have time last nite to look through them all.
    Well, it happened twice this morning just after I left to go to work. So right now I am sitting at Neil Huffman, as I decided that I wanted to go ahead and have them check it out. I'll let you guys know what I find out. Fingers crossed!!
  10. #10
    Certified Car Nut. greatdane68's Avatar
    Donated: $15
    2010 Mazda Speed3
    Join Date
    Sep 2009
    Location
    Georgetown, Ky.
    Posts
    3,277
    Keep us posted Tiff! And good luck with it.
    A modded daily driver is a fun daily driver. Stock Sucks!!!
    My family and my cars are my life, and I consider all of my Mazda peeps family.
    2010 Mazda Speed3
  11. #11
    Registered Member
    04 rx8 GT 6M
    Join Date
    Aug 2009
    Location
    Louisville Ky
    Posts
    220
    My 86 crx did this and it was the ignition switch. I would have to wiggle the key and it would start back up. No need to turn the key cause it was a stick. lol. It got progressively worse till it started acting up when I would try and start the car.
    04 Rx8 GT MT winning blue
    mods: TurboXs catback with Racepipe, BHR coils, K&N typhoon
  12. #12
    Registered Member ScutMonkey's Avatar
    2010 Miata sport
    Join Date
    Feb 2011
    Location
    Louisville (Bon Air, Hikes Point area)
    Posts
    83
    What news?
    I drive topless.
  13. #13
    Registered Member McFly77's Avatar
    Mazda, RX8
    Join Date
    Feb 2010
    Location
    louisville
    Posts
    148
    I agree with bazooka check your terminals, I had this happen to me, and it turned out to be loose terminal. It also happens to sandy's SUV whenever she hit a really big puddle of water becuse of the location of the alternator.
    2004 Nordic Green Mica Mazda RX8
    1996 Super White Toyota Celica GT (DD)
    MODS: Custom Made Clutch, Upgraded Starter, AP Mid Pipe, and HI-Flow Catback, Tokico DSK Adjustable Suspension, Oil Catch Can, K&N Typhoon intake system.
    The choices we make is what makes us who we are.
    I discovered I always have choices and sometimes it's only a choice of attitude.
  14. #14
    2004 Mazda6 i
    Join Date
    Jun 2009
    Location
    Bardstown, KY
    Posts
    1,657
    Quote Originally Posted by caidoz View Post
    Mine is also a manual, not an automatic
  15. #15
    2004 Mazda6 i
    Join Date
    Jun 2009
    Location
    Bardstown, KY
    Posts
    1,657
    Here is the breakdown of the visit to the dealer this morning.
    Ok, so Steve, which is one of the top 3 Mazda mechanics in the country, did the diagnosis on Miss6 this morning. Today there were 2 CEL codes, the usual Lean Idle and the other was something related to the Oil Pressure Sensor.
    Steve thought the latter CEL was caused by the Lucas Oil Treatment I had them add when they changed the oil last week. He said when he had started pouring it into my car he noticed it was thick as molasses and had second thoughts about using it. It is too thick for engines made today, but ok for vehicles like 20 years old. He thinks this was causing the increased oil pressure. So we decided to change the oil again and use a different additive that is safe and recommended for today's engines. Issue #1 of 2 Solved
    The CEL has been on for the past 2 years, since we installed the K&N air intake. It has always read "lean idle". Steve checked for a vacuum leak, but found none. He cleaned the MAF and checked for codes again. On the diagnostic computer it stated that the fuel rating was much more than it should be. So something was telling the ECU to add too much fuel.
    There is something like a vacuum line we had connected to the tip of the air filter. I don't remember exactly what he said this small hose or line was called, but without the stock air box, this line no longer has a purpose. Since we had it feeding into the tip of the air filter, the sensor for this line was giving the ECU false information, thus explaining the increased fuel. The solution was to plug this line and the hole where we had it connected on the filter with a small screw.
    He then cleared all the codes and started my car. Steve ran another diagnostic scan and kept my car running for about 5 minutes to be sure nothing else caused a code to appear and to re-check all of the system functions and ratings. He said everything looked good, so he took it out for a drive around the block to see if the CEL reappeared, and it didn't.
    When I left the dealer this morning, my car felt like it was running better than before. So hopefully now the CEL will stay off and this has solved the issue that was causing the sudden stalls. Fingers Crossed!!!
Similar Threads
  1. Car Alarm going off- randomly on it's own?
    By fraochdha in forum CX-9 Audio
    Last Post: 12-06-2010, 11:13 PM
  2. AC turning on randomly
    By planefreak in forum Protege5 Lounge
    Last Post: 08-26-2010, 07:46 PM
  3. MS3 randomly died...
    By paylew in forum MS3 Lounge
    Last Post: 04-13-2009, 01:13 PM
  4. A/C Randomly Turning Itself Off...Help!
    By RG59061 in forum Mazda3 Audio
    Last Post: 07-07-2008, 04:30 AM
  5. AC randomly turning on and off
    By AFaceInTheCrowd in forum Protege Performance
    Last Post: 08-11-2005, 02:05 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
