Your Best Source for Genuine Mazda Parts!
Results 1 to 5 of 5
Thread: 07 Mazda 3 aux input question
  1. #1
    Registered Member
    Join Date
    Oct 2011
    Location
    TN
    Posts
    2
    Ok, so, I just recently purchased a 2007 Mazda 3, and I am unable to get the media button for the AUX input to work. I've read on multiple sites that the sirius adapter is plugged into this port, but nothing tells me how to reverse that. Is it possible to simply unplug the sirius adapter and use the AUX input again? I don't plan on using sirius, ever, but I'd like to be able to use the AUX port. Any help on this would be much appreciated.
  2. #2
    Registered Member meicalnissyen's Avatar
    07 BM GT
    Join Date
    Jan 2009
    Location
    TAMPA FL
    Posts
    1,837
    The HU has a single input on the back for aux, which can be shared with a sirius, or ipod adapter but only one at a time
    if youve plugged a known good mp3 player into the aux in the armrest, pushed the media button, and it says media on the display with no sound. then someone may have put a sirius adapter into the HU aux, the original aux input wire will be hangin behind the hu, ready to plug back in
    IMHO
    A democracy, in its purest form, is well represented by a group consisting of 2 wolves and 1 rabbit. Voting on what to have for lunch
  3. #3
    Registered Member
    Join Date
    Oct 2011
    Location
    TN
    Posts
    2
    Ok, that helps, but how do I get behind the HU? And what exactly will I be looking for once I do?
  4. #4
    Paramagic icspots's Avatar
    2005 Mazda 3
    Join Date
    Mar 2006
    Location
    Falls Church, VA
    Posts
    1,077
    If when you push the MEDIA button it doesn't change the mode on display then the ACI is not plugged in.
    Remove dash strip
    -pull on it to release the four tension clips (one left of LCD). Gently flex the strip to disengage the hook on the far right (don't pull that part straight out)
    Remove HU
    -remove two phillips screws holding HU
    -Grab HU and pull firmly to release the tension clips holding it in (don't grab the face plate, it might come off)
    Once you have it out make sure you don't let the frame scratch up the dash. Unplug the sirius plug (it's the one on the driver's side). The ACI plug will be somewhere back in there.... it usually got tucked behind a panel or tied off to another harness so it might require a little digging to find. Once you find it plug it in and put everything back in.
  5. #5
    Registered Member geo2maz's Avatar
    MS3
    Join Date
    Jul 2010
    Location
    Denver
    Posts
    2
    I had the same problem when I bought my MS3, I ended up buying the ipod-adapter (the one that lets you control from the HU/steering controls) I pulled the HU, unplugged Sirius, plugged in the Ipod-adapter in it's same-spot, had the wire go to the glove box and left it there... works perfect
Similar Threads
  1. touchscreen 7" text input question
    By speedster59 in forum Mazda6 Audio
    Last Post: 06-10-2010, 08:55 PM
  2. aux input media button question for cx9
    By 9xc8002 in forum CX-9 Audio
    Last Post: 05-13-2010, 11:30 AM
  3. 2008 CX-7 aux input question
    By jimmytango in forum CX-7 Lounge
    Last Post: 11-25-2008, 02:40 PM
  4. 2007 MS3 head unit input question
    By rch in forum Mazda3 Audio
    Last Post: 09-21-2008, 11:33 AM
  5. Odd wheel question.. Please give input.
    By JDuncan in forum MSP Wheels, Tires, Brakes & Suspension
    Last Post: 04-07-2005, 07:08 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
