AzteCypher
black ops modifications..
- 2001 Mazda Protege LX
Well, I decided to put ITB's on my Protege. I know a lot of people say the 1.6 isn't worth working on but it's a stout little engine and I like my car so... why not.
I bought some Haybusa ITBs which measure at 42mm.
I'll be controlling them with this:
Here's a couple of shots with them just sitting on my manifold.
I'm going to see if I can mount the ITBs without separating them. This means that they wont' have a straight shot into the combustion chamber but I can live with that for now. I'm hoping I can cut the manifold at a point where the runners would match up pretty well with the location of the ITBs. I'll use silicone couplers to hold them in place for now.
I'm thinking of using a vacuum block to get vacuum back to the break booster and to any other sensors that may need vacuum. I'm also either going to use the IAC sensor that came with the ITBs or modify the Mazda one to fit. I do have a couple of questions though that I hope someone can help me with.
1) Once I install the Haltech, can I do away with the EGR valve/sensor?
2) I work on computers and automation equipment so I'm planning on installing the Haltech myself. Any tips or advice?
3) If I understand correctly the longer the runners the more torque I get before reaching a point of diminishing returns. Any advice on this?
4) Velocity stacks, how big is too big?
I'm planning on installing the Haltech first so I can learn how to tune it and then do more research before I start cutting up manifolds.
Thanks for looking!
Thanks for looking!
